What steering wheels fit a f100 column?
Discussion in 'The Hokey Ass Message Board' started by bradberry00, Oct 5, 2009.
  1. bradberry00
    bradberry00
    Have a 55 f-100 column/box im putting in my "T". What steering wheels fit the spline of that column without modification...
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    Any splined Ford wheel, car or pickup. Possibly even any GM splined wheel, p***enger car or pickup. Possibly any make splined wheel, p***enger or pickup.
  3. Von Rigg Fink
    Von Rigg Fink
    from Garage
    i have the same question..so..
    any one know make, model and years?
  4. Jalopy Jim
    Jalopy Jim
    I'm not sure on any spline, I have an unknown adptor I tried on my 54F100 colulmn and it does not fit.
    I also would like a different wheel on my 54.
  5. tommy
    tommy
    I can't tell you every wheel that will or will not fit but I can tell you that a 53 Hudson wheel fits fine. My feeling is that you will find more wheels from the 50s that fit than ones that won't fit.
    You might find the spline fits but the hub interferes with turn signal sw. housing. I knocked the housing off of the mast to run this 57 Merc. wheel.
  6. draggler
    draggler
    I know for certain on my 53 f100 column that a 64 chevy splined wheel will not fit the f-1. Or a 3 bolt wheel mystery adapter [splined] also will not fit the f-1 splines and base taper are slightly larger . this does not help but i found an unidentified old style banjo wheel i bought for wall art ,and low and behold it fit the splines perfectly .So the older stuff may have more of a chance to fit the large splines of the mid gen f-1 column.
    Just my 11 cents ,,,,,vern
