What Stupid @ss gears do you run?
Discussion in 'The Hokey Ass Message Board' started by bbscamp, Jul 24, 2010.
  1. Bloodandmotoroil
    Bloodandmotoroil
    ive always held with lots of tourque and tall gears and it's never failed me, if you have the guts then go with the high ones, if you don't then get some and do.
  2. Francisco Plumbero
    Francisco Plumbero
    from il.
    Not happy with 3.23's, wanted 3.73, will try 3.55 or so.
  3. flynbrian48
    flynbrian48
    4.10's in a Dana 70 under the Diamond T, with a 6.0/4L60E. Doesn't really count 'cause it's not finished yet, but it's as steep a gear as I've ever put under a car, er, truck.
  4. Got 2.97's in the '56 F-100 with a TH400. It rules on the interstate.
    Got 4.56's in the '53 Customline with a 4-spd Toploader, I'll probably run out of gear on the big end.
  5. Thorkle Rod
    Thorkle Rod
    Have you thought about converting your 4 speed to a T56 6 speed, some come with a .50, 6th gear, which would get you going down the road at 70 MPH pulling 2100 RPM. They can handle a fair amount of torque, 400 Lbs stock. Lot's more if they are built right. I run 4:56 gears in my 36 with the a 6 speed. Check out this calculator.
    http://www.5speedtransmissions.com/gear_calculator.html
  6. ThePuck
    ThePuck
    from Ottawa
    3.23's and 3000 stall with a 30" tire, is just about the best all around combination. imo. Much quicker on the street than 4.**'s.
  7. No...Toploaders are cool, thats why it has one :) The car isn't done, so after a few test p***es, I'll see whether I need to tone down the gears or not. It won't be a street car so I'm not worried about driveability. The F-100 is the daily driver.
  8. 61bone
    61bone
    6.17 in a 60 pontiac rear under a 55 chebby D/G 12.5 301 with a isky 550 super legerra and kit 2 AFBs on a Offy mid riser and a Mini-Mag. Only used 2nd and 3rd on a saginaw short shaft 3 spd. Lightened till we had to put a tube on the rear for lead shot to make the scale. Wound it to Holy ****. Never got closer than a second off. It was all fun till somebody put an eye out.
    Today, 3.70 is about as deep as I go.
  9. ray
    ray
    from colorado
    stupid in the other direction,
    2.66 in my c-10. with a t-5 in front.
    stoopid me, hit the u pull n pay for a rear for my 5-lug conversion, i look for the best looking, easiest to pull, which was slim pickins that day. i didn't pay any mind to gears, figuring just about every chevy truck is going to have 3.43 or 3.70 gears. get it home when i pull the cover to inspect it and see a pinion gear the size of a dinner plate. doh! it actually does ok. the splits are big, but the motor has decent torque. 5th gear is now pretty much reserved for freeway blasts.
    for ****s n grins i just plugged my numbers into a top speed calculator, stupid indeed. dammit, now i gotta go find out for real.
  10. nanos1932
    nanos1932
    31" tyre, 4.56 limo, powerglide (3000 stall), blown sbc, 5 window. Hang on:D
  11. NITROFC
    NITROFC
    I have a Versailles rear in my 36 dodge with a 2.50 gear and T350... Wouldn't trade this combo at all. Found 2 complete set up's just in case
  12. I did stupid the other way, too, my old Suburban beater - which I used to tow a bunch of old cars home - was built with a 350, 700R4 and a 2.73 locker. It got great milage at 75 mph.
    So keeping with the tradition I managed to find a one-ton van with a 3.23 in it... computer shifts it to OD about 45 mph and bleh, I have to keep it in D until I'm doing 55 if I want to make it to 65 in less time than it takes to brew a pot of coffee. On the bright side, it gets 11 MPG towing 4500 lbs.
  13. RDAH
    RDAH
    from NL, WI
    Runnin 3.89's with an AOD. & carbed 91 302 in my 54 Merc. 22mpg & she'll bring the front end up & squat nice on the street.
  14. FrozenMerc
    FrozenMerc
    On the other end of the spectrum. My '51 runs a 3.08 rear with 0.67 OD. 1700 RPM @ 70 mph.
  15. 57Custom300
    57Custom300
    from Arizona
    57 Ford, 292, 3sp, 4:11. Would just scream at 55 in the right lane. Toned it down this year w/a T5. 1800 @ 65
  16. Von Rigg Fink
    Von Rigg Fink
    from Garage
    4.56 in a O/T Dodge 440 with 727 trans..p***es everything in the first 1/4 mile..except a gas station (although right now its just sitting)
  17. cruisin30
    cruisin30
    from Katy, TX
    The 32 runs a 327, TH350 and 3.08 Corvette rear. Shes a driver, not a racer. 2300 at 65mph.
  18. Sigspeed
    Sigspeed
    456s in my 68 L89 vette I drive it 3 or 4 times a month
    50 in the right lane
      347.5 KB
