Good Day, Looking to find out what sway bar should i use for a 62 falcon. The cross members is a R&C with tubular a-arms and from sway bar mount measures approximately 44.5 inches hole to hole center. would you suggest a 1" or larger bar in the front of this car? Is there a particular brand or model that you may suggest? Looking at placing a order on this item this evening so i can get the car back n the ground and continue moving on it. Thank you for the help in advance. Ron
I will try to get you a part number or two and yes a 1" in front it looks like you are running a R&C MII setup so that's who I would use on the sway bar::: RC-123 $164 Now on the rear if you are going to make your car into a hot rod then I would use Heidts rear coil over kit it's 1,500 which is not bad for a kit you can piece together a system from Summit but you will have to call Summit and see what they can do for you.A 4 link will run you between 2 to 600 depending on what you want the car to do and a coil over system is 4 to 500 so now it's up to you but you have to ask yourself what do I want this Car to dne more thing if I was you I would go and check out BurntOutOldMechanic Falcon build it will give you a laugh and Teach you more than I ever could He is a very Good Mechanic
