What Switch Do I Need?
Discussion in 'The Antiquated' started by Truck64, Mar 7, 2022.
  1. Truck64
    Truck64
    from Ioway
    Figure there has to be some electrical types here. I want to replace this switch, goes to a restored/restomodded tube type stereo amplifier - Dynaco 70. Looks like 6 amps @ 125 VAC.
    Just need "ON" and "OFF", not a complicated guy.
    When I went poking around the intertubes I get "ON" & "ON" switches, and "ON/OFF/ON" switches. I didn't see any "OFF/OFF" switches, but knowing my fat thumbs I'll somehow order one by mistake.
    The panel opening is 1/4" hole. What switch do I want to order? Please use small words that are easy to understand. Single throw, double pole? Thanks!
    C9C346AF-B720-4EC9-B35B-6E887B8B630B.jpeg 19744E76-230A-4E10-9509-4F3415C0B01E.jpeg
  2. pprather
    pprather
    Can't tell from the photo.
    Is this a rotary switch or a toggle switch?
    Is there any I'd info on the silver plates on the side of the switch?
    Truck64 likes this.
  3. Truck64
    Truck64
    from Ioway
    Yeah, just a simple "Up" for "On" and "down" for "Off". Like a cl***ic light switch I guess.
    CC31CCA0-536B-4FB8-BF49-98C9684C90A2.png 198B9340-7662-4768-BCB3-2D10526784DE.png
  4. pprather
    pprather
    Truck64 likes this.
  5. pprather
    pprather
  6. Truck64
    Truck64
    from Ioway
    Thanks for your help
  7. pprather
    pprather
    Let us know if the switch install gets your unit back in service.
    Truck64 likes this.
  8. banjorear
    banjorear
    On/off switches are the most common out there.
    For this, I would go to an electrical jobber shop. They have many different switches that big box stores don't. This way you can match up the amps/panel hole size, etc.
    Truck64 likes this.
  9. Without being a smart****, can i suggest you tin those wires before you solder to the new switch, those joints look dry to me. And don't have the wire sticking out of the lugs.
    Plenty of youtube videos on soldering electronics.
    Truck64 likes this.
  10. Truck64
    Truck64
    from Ioway
    You noticed that too. Yeah the soldering looks like an afterthought, don't it?
  11. Chebby belair
    Chebby belair
    from Australia
    A simple On/Off toggle switch is called Single Pole, Single Throw. You'll see switches in electrical catalogs labelled SPST. This is what you want.
    Truck64 likes this.
  12. Truck64
    Truck64
    from Ioway
    OK, I've had two of them delivered today in my mailbox for $5.95, can't argue with that. They look identical. So I got that going for me, which is nice.
    One question though, does it matter which way it is connected with only the two wires? I think "No" though I'm no spark chaser.
    Even I can't screw up the function of the switch, I know it will work, BUT, is there some kind of safety or ground issue here, excessive hum or something, if it is hooked up "wrong"? If there's a 50/50 chance of connecting it wrong, I'm pretty sure I'll find it.
    The unit has been updated to include a polarised plug.
  13. pprather
    pprather
    Can wire either way. A switch is just a break in a wire.
    When you mount the switch in the panel, position it so up is ON.
    Truck64 likes this.
  14. theboss20
    theboss20
    And as always don’t forget: mouser.com
    Truck64 likes this.
  15. Truck64
    Truck64
    from Ioway
    Can Mouser send even a single switch for six bucks though? They are a great company, most mail order wants a minimum order.
  16. pprather
    pprather
    @Truck64 , is your equipment now repaired?
    Truck64 likes this.
  17. Truck64
    Truck64
    from Ioway
    Can't see any reason why it wouldn't be? I haven't actually tried it just yet, need to get everything hooked up. One, it weighs almost 30 pounds. Unlike transistor gear these need to have speakers hooked up when turned on. It also doubles as a space heater. Sort of dragging my feet or taking my time getting it ready to sell.
    I'm afraid I'll want to keep it. It is a very excellent design overall.
    Tested the power supply capacitors and they are all excellent.
    pprather likes this.
  18. Chebby belair
    Chebby belair
    from Australia
    Shouldn't matter which way you wire it, but a better solder job would be nice.
    Careful how long you leave the solder iron on the switch when you're soldering it. The heat can start to melt the plastic on those little switches if ya get carried away.
    Truck64 likes this.
