Hot Rods what Tachometer will work with a vertex mag
Discussion in 'The Hokey Ass Message Board' started by W6RAT, Dec 13, 2018.
  1. W6RAT
    W6RAT
    from Coos Bay
    what Tachometer will work with a vertex mag without a tack drive.
    the only ones I have found are from autometer clubman series and they are to expensive and don't even look all that good. the mag has a internal coil. is there anything that will git a reading from a plug wire. any help would be appreciated ... Thank You
  2. yellow dog
    yellow dog
    from san diego
    50 years ago I simply used a Zener diode SW with a Joe Hunt Vertex. A quick look doesn't seem
    like anything easy came up.....however magnetic pickup style tachs (diesel) are pretty abundant
  3. drtrcrV-8
    drtrcrV-8
    Call Speedway motors & ask the same question...…..
  4. tubman
    tubman
  5. 1934coupe
    1934coupe
    We run Sun tach's with the transmitter box that says "Mag" on it. I have added some examples on ebay. They are restorable and a company I think the name is Williamson can convert the box to transistor. http://www.williamsons.com/Tachometers.php they did ours and it works great.
    Pat
    Vintage Sun Eb-9 Tachometer and Transmitter Sender 12v 8 CYL | eBay
    https://www.ebay.com › ... › Car & Truck Parts › Gauges › Tachometers
    Find great deals for Vintage Sun Eb-9 Tachometer and Transmitter Sender 12v 8 ... SUN TACHOMETER TRANSMITTER TACH EB-9A HOT RAT ROD G***ER ...
    vintage sun tach 2245-25 & tachometer transmitter eb-9a 12 ... - eBay
    https://www.ebay.com/...SUN-TACH...TACHOMETER-TRANSMITTER-EB-9A...-/3...
    VINTAGE SUN TACH 2245-25 & TACHOMETER TRANSMITTER EB-9A 12 VOLT 8 CYLINDER | eBay Motors, Parts & Accessories, Car & Truck Parts | eBay!
    SUN EB-9A TRANSMITTER tachometer new - Auto Parts Obsolete
    https://autopartsobsolete.com/SUN-EB-9A-TRANSMITTER-tachometer-new.html$195.00 - ‎In stock
    This sale is for a new never installed in old original box with instruction sheet EB-9A transmitter note inside of transmitter is good but has some minor little ...
  6. AngleDrive
    AngleDrive
    from Florida
    X2
  7. RichFox
    RichFox
    I have a tach here that I used when I had a mag. But it is for a 6 cylinder engine. I can look for it if you want.
  8. typo41
    typo41
    We finally had a tach drive added to our base cause most tack companies today had nothing and the control boxes I heard about work but around $350 it was easier to run the cable tach
  9. Paul
    Paul
    Editor
    Any experience with Auto Meter tachometer signal converters?
  10. 1934coupe
    1934coupe
    Yeah I could not get it to work. As I said earlier I found a Sun tach and had a new face put in it to the red line I wanted then had the box transistorized and I don't think I have $450. in total. And it is exactly what My MG had in it in the 60's. I have a Vertex mag and had a spare with the tach drive cable on it and I didn't like the way it looked or the cable going through the fire wall.
    Pat
    Paul likes this.
  11. Mike VV
    Mike VV
    from SoCal
    Autometer "used" to have one of their race style, 5" tachs. for the Vertex.
    I had one in my Anglia.
    Mike
  12. tubman
    tubman
    Odd. Mine worked extremely well with no problems. Yours was probably either defective or improperly wired.
    Paul likes this.
  13. Paul
    Paul
    Editor
    thanks,
    I ask about the Auto Meter converter because I've been wanting to swap the oil and water gauges in my firewall to this 2-1/16" tach and vacuum set.
    'don't want to spend a hundred bucks on something that may not work..
    I do have another magneto with a tach drive but I don't want to use a big tach
  14. 1934coupe
    1934coupe
    Tubman you are probably right. I got it used and it is still in car just not used.
    Pat
  15. W6RAT
    W6RAT
    from Coos Bay
    Thank you but I need one for a 8 cylinder
  16. deathrowdave
    deathrowdave
    from NKy
    I have done it 2 ways : 1. Signal converter as suggested 2. The P (pulse terminal ) on the Alt to drive a pulse drive tach . Auto Meter has a sending unit that clamps on the OD of the Alt , I have used on a few diesels that works good but it takes adjusting to calibrate it correctly . It seems to work find throughout the RPM range when correctly calibrated
  17. W6RAT
    W6RAT
    from Coos Bay
    a tach drive cable would be the easy way to go ... do you still have the tach drive part ... a cable through the firewall wouldn't bother me
  18. W6RAT
    W6RAT
    from Coos Bay
    Is the magneto sumthin you want to part with
  19. Budget36
    Budget36
    I've a tach in my '82 diesel..runs off either the lower pulley or the crank balancer (been ages since I looked)..just a strobe. Seems like that would work too?
  20. 1934coupe
    1934coupe
    W6RAT I got rid of it a long time ago. There are plenty for sale on ebay though, I get the reminder all the time. Just remember "easiest is not always best".
    Pat
  21. jimmy six
    jimmy six
    Google "Stack Clubman" magneto Tachometers.....
