Folks Of Interest What the heck is it Radiator cap pressure testerr
Discussion in 'The Hokey Ass Message Board' started by stanlow69, Mar 31, 2023.
  1. stanlow69
    stanlow69
    I thought I would post this before April First. It accepts a radiator cap on both ends. What is it? It came with a bunch of mechanic`s tools. DSCF0170.JPG DSCF0172.JPG
  2. TA DAD
    TA DAD
    from NC
    A adapter for a pressure tester for radiator caps
  3. fastcar1953
    fastcar1953
    we have a winner.
    VANDENPLAS and Mr48chev like this.
  4. stanlow69
    stanlow69
    It took 3 minutes. I imagine it will work for a Dodge. Since they go bad more often.
  5. Bandit Billy
    Bandit Billy
    One end should be deeper than the other inside, to fit both short and long reach caps. If they don't seal, you can't test em.
    winr, VANDENPLAS, egads and 2 others like this.
  6. X-cpe
    X-cpe
    Mine came with a thick washer to make up the difference if needed.
    Bandit Billy, 2OLD2FAST and egads like this.
  7. BJR
    BJR
    Pressure pump on one end, cap to be tested on the other.
    egads likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. fastcar1953
    fastcar1953
  10. Lone Star Mopar
    Lone Star Mopar
  11. i7083
    i7083
    That's cool! So to speak...
  12. Mr48chev
    As Moriarity and Fastcar1953 Showed it is part of every radiator pressure tester kit that is used to test the caps. That kit is very often used to test caps more than the radiators.
    VANDENPLAS likes this.
  13. stanlow69
    stanlow69
    When you turn your clocks back, change your batteries in your smoke alarms and check your pressure in your radiator cap.
    Lone Star Mopar likes this.
  14. TagMan
    TagMan
    I have an old radiator pressure checker which has a bad rubber piston seal. Anybody know where to buy parts for these things? No name on it and it doesn't look as simple as just replacing the rubber seal.
    Thanks, -Bob
  15. stanlow69
    stanlow69
    Pictures ?
  16. leon bee
    leon bee
    Test every 4 months, I'm a little behind.
  17. stanlow69
    stanlow69
    It`s the same depth on both sides.
  18. I have a Stant brand pressure tester and it’s the the same on both ends too.
  19. TagMan
    TagMan
    Hrere's a pic of my radiator pressure checker and the two extra adapters it came with....
    [​IMG]20230402_151113 by TagMan, on Flickr
    stanlow69 likes this.
