What the Heck is this Tool For?
Discussion in 'The Hokey Ass Message Board' started by FoMoCoPower, Oct 22, 2007.
  1. FoMoCoPower
    FoMoCoPower
    A friend gave me a bunch of his old tools a few years ago,and he gave me this also,but wouldn`t tell me what it was for.....all he said is that I will figure it out some day....well i`m tired of waiting....what the hell is it????
  2. Phil1934
    Phil1934
    can't see business end but I had a similar stuck lifter puller
  3. Kamp
    Kamp
    from Peoria, IL
    Yup, for pulling lifters.
  4. 49ratfink
    49ratfink
    looks like a nipple twister to me...
  5. Crankhole
    Crankhole
    Yep, "Deluxe" model.........the gold handle gives it away.
  6. skratch
    skratch
    prop it on your shoulder and lean on a panel to tig weld it ..or you can lifters with it .
    my nipples don't twist .
  7. donzzilla
    donzzilla
    It'll work on the lifters,as there is a little edge on them at the top. but I think technically, it's a blind bearing puller. When a bearing, mostly needle bearings are pressed into a hole there is no way to tap or press them out from the other side. You insert that end, tighten up on te nuts and that little flared end will expand a bit. Warm up the surrounding area a little and use the weight to hammer up on the tool to pull the bearing out. They usually come with a couple of different sizes. But you can only get them in one size for a one job deal.
    Hope this helps, Don
  8. 51 MERC-CT
    51 MERC-CT
    Sort'a looks like a blind bearing puller, like this one:) :D
  9. junior 1957
    junior 1957
    naaa... mechanical viagra:D :eek:
  10. That's,"Visually-impaired" bearings if you please!:D
  11. squirrel
  12. FoMoCoPower
    FoMoCoPower
  13. The lifter puller I bought new over 30 years ago had two jaws on it that spread out into the snap ring groove when you twisted the handle. I don't see the two jaws on this tool but the rest of it looks identical to my lifter puller. Perhaps someone's modfied it.
  14. squirrel
    from the link in my previous post:
    "13750
    Hydraulic Lifter Puller
    Remove Stuck Hydraulic Valve Lifters.
    Expanding Collet Firmly Grips the Tightest Lifters. Special Designed Slide Hammer Jars the Lifter Loose."
