What the heck is this?
Discussion in 'The Hokey Ass Message Board' started by Heckler, Jul 28, 2009.
  1. Heckler
    Heckler
    from Austin, TX
    I work in Facilities Services at the university, and I showed it to a few mechanics, and 1 guy thought it was a special wrench for an old car AC compressor. Sounds fishy to me, but I just don't know what else it could be. What do you think?
  2. 49ratfink
    49ratfink
    looks like somethiing for sprinkler or plumbing installers
  3. Soviet
    Soviet
    Looks like a grinder wrench of sorts.
    Champion Irrigation is in LA - very well could be sprinkler/plumbing as fink said.
  4. squirrel
    google champion brass, they make sprinkler systems...
  5. Milhouse
    Milhouse
    from RI
    I agree with boristheblade, we have a similar wrench here for an old precision grinder in our shop. The hex end is for the center nut on the spindle, the two prongs are for the threaded washer that holds on the grinding wheel.
  6. 61TBird
    61TBird
    Irrigation (sprinkler)wrench
  7. PGrazz
    PGrazz
    from SL
    It's a sprinkler wrench for the old metal lawn sprinklers. The larger "forked end" tightens the entire sprinkler to the pipe and the hex-end is for installing/removing the top of the pop-up head when it gets clogged.
  8. Heckler
    Heckler
    from Austin, TX
    Got it. Irrigation wrench. Thanks!
  9. I Drag
    I Drag
    It's a pen. The 4 color kind.
    Just bored today.
  10. temper_mental
    temper_mental
    from Texas
    Spanner wrench used to turn fire plugs hydrants on off. One side takes the cap off the other turns the water on. Worked in the water dept years ago. That's my guess
  11. "Whitey Ford" 62 Uni
    from Tampa, FL
    HAHA....that reminded me of something my pop would say.
  12. 327-365hp
    327-365hp
    from Mass
    My guess was a wrench for 55 gal drums. Brass makes no sparks.
  13. O.Hove
    O.Hove
    from S.D.
    To small for a fire plug. It's for removing large screw in plug on an oil drum.
    Small end for air plug. You put the spigit in before you use a drum turnner
    to lay drum on it's side.
  14. squirrel
    Oh...it's one of these?
  15. Kramer
    Kramer
    Yep sprinkler wrench, I have one laying around in my garage somewhere. That wrench might even still fit some of the sprinkler heads around the university there.
  16. similar to an older ac wrench..but they were not brass...
    and there would be no need for the box end wrench of that size.....but what do i know, could be........:confused::confused::confused:
  17. poofus1929
    poofus1929
    from So Cal
    Yup it's a sprinkler wrench. My mothers house still has a few Original metal Champion sprinklers from when the house was built back in the mid 70's.
  18. 55chevr
    55chevr
    fire hydrants use a 5 sided box wrench not 6 ...
  19. temper_mental
    temper_mental
    from Texas
    Well hell I was wrong
  20. 52style
    52style
    looks like a spanner wrench to me
  21. Beau
    Beau
    Dodge Ball pratice wrench.
  22. Thats a Flux capacitor adjustment spanner.
