What throwaway gloves stand up to thinner & reducer?
Discussion in 'The Hokey Ass Message Board' started by atomickustom, Oct 18, 2013.
  1. atomickustom
    atomickustom
    So I had a box of latex examination gloves in my garage and they worked great for paint or filler, but lacquer thinner and enamel reducer both make them fall apart, at which point they are worse than wearing nothing at all.
    Are there relatively inexpensive, disposable gloves that won't fall apart the second some thinner or reducer touches them? I'm trying to save my skin and brain here.
  2. slowmotion
    slowmotion
    Go to a medical supply house. Ask for proctologist grade. They stand up to a lot of shit.
    Couldn't resist....:D
  3. 1955IHC
    1955IHC
    Only thing that will hold up is Nitrile gloves. They look just like regular old rubber gloves. They are also good for people with silicone alergies.
    Sent via Illinois Bell Telephone Company's Car Radiotelephone
  4. 63comet
    63comet
    I use nitrile at work so if I need gloves at home that's what I use.
    I can tell you there are solvents that will destroy nitrile too though. I had a fresh tattoo on the back of my hand at the same time as my carb chose to take a dump. The carb cleaner I was using turned the gloves brittle in no time.
    Kind if worries me as, from my timy bit of knowledge, seals and diaphragms in fuel systems are often nitrile.
  5. Fenders
    Fenders
    Nitrile (Buna-N) is often used in carbs..... Viton is said to be better able to stand up against ethanol....
  6. There is always a comedian! :rolleyes: HRP
  7. atomickustom
    atomickustom
    Nitrile it is. Thanks, everyone!
  8. They don't work for me. In my experience, they will swell and deform when they come in contact with paint thinner.
  9. atomickustom
    atomickustom
    Oops! I just realized the gloves I had WERE nitrile. (I have the end of the box in my pocket to remind me to ask.)
    Are they the best I can do?
  10. AZbent
    AZbent
    At work here the ground equipment mechanics use a black disposable glove, similar to what you are using. They say that they are better around chemicals, don't swell up like the gloves most of us use. They gave me a few pairs to try out, I haven't gotten that far yet.
  11. 1955IHC
    1955IHC
    Quality makes a big difference. The ones I get at work hold up a hell of a lot better then anything I buy. My friend who tattoos also agrees. Not sure what brand they are, I'll take a look when I get a chance.
  12. jkeesey
    jkeesey
    you can buy a pack of the thicker hazmat style gloves at harbor freight for pretty cheap. They stand up to lacquer thinner for a while.
  13. fsae0607
    fsae0607
    As far as throwaway, nitrile is the way to go but they'll eventually break down.
    Next step up is the neoprene gorilla gloves that they sell at homey depot. For $8 they'll last.
  14. I always use regular latex gloves that I get from the auto body store and have never have a problem with them.
  15. shadams
    shadams
    HAAAAAAAAAAA!
    Yea I have the same problem, I was using thinner to clean something and
    they got all soggy. Have to try some better quality ones.
  16. RocktimusPryme
    RocktimusPryme
    Im an A&P mechanic. We use MEK on occasion. Vile stuff. We mostly use a good barrier cream. Order of the day is still limit contact as much as possible. Gloves made of Butyl work for it I think, and I believe seen some gloves that have barrier cream on the gloves itself.
  17. Thickster 14 mil. Nitrile gloves. I worked at a body shop and had to submerge my hands in paint thinner for a long time sometimes and they always held up. A pair would last me 8 hours no problem. Sometimes 2 to 3 times that.
  18. 1971BB427
    1971BB427
    from Oregon
    I haven't found "throw away" gloves that stand up to hot paint reducer. I keep a pair of heavier gloves for working with reducer, and then remove them once that part is done. That way I don't have to continue buying more when I need them for that task.
  19. Bugguts
    Bugguts
    I second 1971BB427. I do just what he does.
    We use nitrile only and they will swell and tear after too much contact with solvent.
  20. aaggie
    aaggie
    No matter which gloves I use I double up, put on two pairs. The purple colored Nitrile gloves are the best disposable gloves I have tried so far.
  21. cool....thanks - great thread....
  22. Clik
    Clik
    Galeton.com is where I get my gloves. Pretty good desciptions of what works for what.
  23. 63comet
    63comet
    A lot of the companies simply color code by size, so that's not always an indicator of quality.
    I can tell you the purple ones from the drugstore are garbage.
    If you're going through lots of them you'll save money ordering by the case. The place I use I think I'm paying $65 or so for ten boxes of 100 gloves? If you have smaller hands its often 120 to the box.
    I also like this place because they let me mix and match to make up a case, so if I'm splitting an order with a coworker or want to try something different it makes it easier.
  24. Rex_A_Lott
    Rex_A_Lott
  25. OLDSMAN
    OLDSMAN
    I use nitril gloves. They happen to be blue in color. They hold up great to lacquer thinner. I use them a couple of times and then throw them away
  26. Playtex living gloves. 2-3 bucks. Work great.
  27. atomickustom
    atomickustom
    Sounds like I just need to buy some thicker, better gloves. Thanks, all.
