Technical What to clean corroded carb internals with?
Discussion in 'The Hokey Ass Message Board' started by HB., Apr 4, 2016.
  1. HB.
    HB.
    from East TN
    I picked up an edelbrock carb to stick in my F100 and everything inside that is br*** is corroded. I don't want to use CLR or anything since it's soft..but what can I use? My finger and carb cleaner isn't taking it off and I don't want to put it back together like that. Any suggestions?
  2. Larry T
    Larry T
    I sometimes use household Lime Away. Or there's a "naval jelly stuff" for aluminum that works.
  3. gimpyshotrods
    gimpyshotrods
    White vinegar and a toothbrush.
  4. joeycarpunk
    joeycarpunk
    from MN,USA
    I too have used vinegar.
  5. I acid dip the stubborn ones......beadblast the ones you would throw away.....
  6. HB.
    HB.
    from East TN
    Thanks! I'll give white vinegar a shot tomorrow evening and see how it turns out.
  7. luckythirteenagogo
    luckythirteenagogo
    from Selma, NC
    I've used an ultra sonic cleaner in the past. They are great. Throw your parts in with some warm water and vinegar, and they look as good as new inside 30 minutes. The best part is there is no scrubbing. You can stick them in, turn it on and go have a beer. I know HF has one big enough to fit a carb for like $70 before your 20% coupon.
    Sent from my SM-G920V using H.A.M.B. mobile app
  8. bchctybob
    bchctybob
    I usually use maroon Scotchbrite on the br*** parts. When I'm really bored, I follow that with Br***o ...... shines like a new dime.
    If the floats are really corroded, I'd float them in some gas to be sure they float.
  9. Andy
    Andy
    I have had good luck with Ospho. Don't let it stay in any time at all!!!
  10. gimpyshotrods
    gimpyshotrods
    That's why I like vinegar.
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Good old ethanol strikes again! Just recently did a rebuild on one I soaked the insides with PB Blaster and let it sit over night it turned the scaly snowing looking **** to a mush that aerosol Carb cleaner could spray off. Some parts were then buffed with 000 steel wool.
