Hot Rods WHAT TO DO ABOUT MY 727 TORQUEFLITE..........A DILEMMA....... REDUX
Discussion in 'The Hokey Ass Message Board' started by 34Larry, Nov 21, 2020.
  1. justpassinthru
    justpassinthru
    Thats a good plan. Brady will probably be able to tell whats in there and that way you can go on his recommendation.
    Bill
  2. Johnboy34
    Johnboy34
    from Seattle,Wa
    Your real close to being done Larry, a little more patience and you'll be driving that cool hot rod in the very near future!
    Sent from my SM-G973U using The H.A.M.B. mobile app
  3. 34Larry
    34Larry
    Thanks guys. Would trailer it to brady or drive it??
  4. I wouldn't drive it even out of the garage without knowing for sure if it needs the tv hooked up. There is no reason to risk damaging a fresh transmission.
    I have gone through the same kind of issues with transmission shops in the past, but have been lucky to find a great transmission guy who goes out of his way to stand behind his work.
  5. greybeard360
    greybeard360
    You have to be careful using a manual valve body on the street. TF do not like to be downshifted into 1st unless under power. If the wheels stop turning abruptly for even a split second it can and will spin up the direct clutch drum and explode it. If you have seen photos of a TF laying on the ground in a million pieces, that is what happens. Your best bet is to put in a stock valve body with a B&M shift kit and hook up the TV linkage. You will enjoy driving it and not worrying about it.
    b-body-bob, loudbang and lemondana like this.
  6. 34Larry
    34Larry
    >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Thanks for the heads up gb. I know about down shifting into first and the havoc it can cause.
  7. 73RR
    73RR
    ^^^^^^^THIS....I have zero use for manual valve bodies even if making linkage is a PITA.
    lemondana and loudbang like this.
  8. TA DAD
    TA DAD
    from NC
    Depends on what valve body you have, some have no engine braking in first gear.
    b-body-bob and loudbang like this.
  9. If your thinking about getting away from the manual valve body, buochillon performance makes a great kickdown set up that can adapt to damn near any engine/induction combination. It is much nicer then the lokar and easier to adapt then a stock linkage.https://www.bouchillonperformance.com/
