Art & Inspiration What to do with an old camshaft?
Discussion in 'The Hokey Ass Message Board' started by MrBelvedere2, Sep 6, 2012.
  1. MrBelvedere2
    MrBelvedere2
    from Davis, CA
    Hey guys, I have an old used camshaft out of a 331 Chrysler Hemi I found in a pile of junk with some motorycycle parts. I assume since it's used it isn't worth much. What neat ideas have you guys come up with for a use for them? I did see a thread on here with a couple of uses for them. I know you guys have come up with some great ideas, post em here!
  2. spot
    spot
    from usa
    I keep one leaning against the door frame of the shop and use it to help remove unwanted visitors.
  3. hammered30
    hammered30
    from west aus
    Front spreader bar that looks cool
  4. traffic61
    traffic61
    from Owasso, OK
    I've been thinking about fabricating some end brackets and using one for a towel rack in the bathroom.
  5. chaddilac
    chaddilac
  6. Ole don
    Ole don
    Send it to a competent regrinder and use it in the next engine you build.
  7. -DMC-
    -DMC-
    from Ohio
    Yeah that front end is cool...^^^
    I had 3 old cams and used them for legs with a fly wheel for the top. Wasnt the sturdiest so I just put it outside garage with a plant on it...
  8. slowmotion
    slowmotion
    Had a chance to get one out of an EMD locomotive once. Thought it would have made a great mailbox post.
  9. icsamerica
    icsamerica
    weld a 1/2 inch extension to one end and use it as a breaker bar.
  10. I'm in the middle of building a coffee table and end tables using them for legs
  11. Erkenbrand
    Erkenbrand
    1. Rochester NY HAMBers
    Leave the timing gear on, and with a little welding magic make a lamp. I have a great bench lamp I made from a 4.3L Chevy cam.
  12. 57tony31
    57tony31
    from Woods
    440 cam here:D
  13. 1931modela
    1931modela
    from montana
    paper towell or shop towell holder.. weld it to a timing gear at a 45 and mount the gear to the wall with the 45 pointing up and slide your roll of hand wipers on it.
  14. young'n'poor
    young'n'poor
    from Anoka. MN
    WWDD? (what would Denise do) I'm sure you can find a nice way to integrate that into your home decorating...
  15. squirrel
    early hemi cam? I'd sell it on ebay.
    Used small block chevy cam? They all seem to end up in the scrap heap, each one is worth a few cents when I haul in a load of iron.
  16. Drop it on the concrete so it hits horizontiley...You will then have 2.
    Make some trick headlight stands
  17. hotrodladycrusr
    hotrodladycrusr
    Me too! LOL
    ROTFLMAO! :D
    I've been collecting them and plan on doing a couple of side tables for the living room with flexplates and glass on top.
    So many projects, so little time.
  18. brian55lvr
    brian55lvr
    from ma
    get a bunch and make a handrail--- cranks on corners -----thats my plan
  19. Gomojo55
    Gomojo55
    I've seen people use them as spreader bars and split bumpers. They look cool!
  20. They a good cam bearing ream for when you knick one that you have just installed and cannot get the new cam shaft in. You cut a flute in the journal and slid it in until it stops then turn it and apply slight pressure until it goes.
  21. rottenleonard
    rottenleonard
    I think the best use for a used camshaft is to walk by the new guy in the shop carring it like its a 3 minute old baby then "accidentally" trip over anything convienient that they left laying on the floor and drop it, It will usually snap in two when it hits the floor. Then watch how big their eyes get when you say"Who the hell left that laying there?"
  22. ironpile
    ironpile
    Use it to stake your pole beans.
