what to flush gas tank with?
Discussion in 'The Hokey Ass Message Board' started by GARY T., Jun 17, 2010.
  1. GARY T.
    GARY T.
    from S.W. Pa
    Have to change gas tank on wifes car--bought a used one --good shape , but looks like a little varnished gas and maybe some dust in it.Should I just swish some gas around in it and drain it ,or is there something better to do?
    thanks
  2. JohnEvans
    JohnEvans
    from Phoenix AZ
    Denatured alcohol works good at getting the varnish out.
  3. rottenleonard
    rottenleonard
    I've cleaned out motorcycle tanks with laquer thinner worked well on varnish but won't touch rust.
    Robert
  4. lorodz
    lorodz
    my sound funny but i used some gas let it sit for a couple days and than flushed it out with water and all the varnish came out with it ..
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    if the varnish is thick ..while using a solvent..throw some small nuts or bolts that will come back out easy to help loosen up the s***..put them in and shake it up while its sealed off with some tape.
  6. Tech @ BG
    Tech @ BG
    Years ago I used to carry them to the radiator shop and have them vatted but not sure if they still do that or not.
    One thing to keep in mind if it is a pump gas application is that with the 10% ethanol in the fuel now it is acting like a detergent and cleaning any deposits in the older tanks and sending them upstream so make sure and get everything you can out. Filters will not stop a lot of this stuff either as it is showing up as a sticky residue at the carbs.
  7. chaddilac
    chaddilac
    Throw a small chain in there and slosh it around!!
  8. gimpyshotrods
    gimpyshotrods
    All of the ones I work on go to the local radiator shop to get boiled out. It makes welding, sealing and lining a snap (and not a BOOM!).
  9. moefuzz
    moefuzz
  10. R Frederick
    R Frederick
    from illinois
    I bought a gallon of paint stripper for my last tank, it cut ALL the brown varnish nicely. I then pressure sprayed it out.
  11. big creep
    big creep
    x2 here they still do that,this is your best bet if you can get it done. pretty cheap too.
  12. Acetone is the main ingredient in Absorbine Jr. muscle linament. Safe to rub on your aching muscles!
  13. 49ratfink
    49ratfink
    seems like when I did my motorcycle I used kerosene.
  14. 40hemicpe
    40hemicpe
    from anaheim.ca
    for my cars&bikes i use diesel soak it for a little then put a chain in there and slosh it around
