Thinking about picking up a unibody to make into a "shop truck" for my pinstriping and cruising around. From others I've seen I know to watch the front fenders and the rear cab corners for rust. Where else should I be checking out? Also it's now powered by a 351m backed by a c6 any particular issues to check for in this combo? So far the pics look like it's in ok shape. Just want to make sure I don't miss anything and drag home a lemon If I bring it home I'll be looking for low buck tips to sit it down in the weeds.
The search is your friend... this first thread seems to answer most of your questions http://www.jalopyjournal.com/forum/showthread.php?t=480916&highlight=ford+unibody these other ones might be if use as well.. http://www.jalopyjournal.com/forum/showthread.php?t=225699&highlight=ford+unibody http://www.jalopyjournal.com/forum/showthread.php?t=478327&highlight=ford+unibody
Thanks for the links. Now and then I forget the search. It works well here, every other forum I'm on it doesn't.
another good tip to search here is do it from google. http://www.google.com/advanced_search?hl=en then just search within jalopyjournal.com
