37 slantback/fastback/flatback cars came in both Tudor (desireable ones) and Fordor (parts cars for Tudors/Coupes) versions. Any of these would give you a usable front axle , spindles for your A and a banjo rearend if that is what you want/need. Spindles are 37-41 Car and Pickup, 42-48 Car an 42-47 pickup spindles are good too. Do some heavy reading to get a knowledge base for doing your first hotrod. That will save you alot of missteps, both monetary and otherwise. Get after it.
Thanks for answering my question with detail and taking the time to educate! I'm reading up as much as I can, but of course when a deal comes up you have to jump and don't always have time to do your homework. Picked up the 41 ford this weekend. Body is actually WAY nicer than I expected, but still it is missing so much interior, etc that I don't think it's worthwhile to restore or flip this 4-door sedan. I'll be parting it out. Got the suspension, two steering columns with steering box, juice brakes, pedal set, driveline and banjo, and my 16" wheels all for the roadster. All said the entire car was well south of $1k so I'm happy as a lark. Loading her up Brought along my little helper Home in the garage
I have a '40 front axle. If you split the bones and have a relatively narrow ch***is, you can do a "Rolling Bones" style front suspension with perch pins through the wishbones using a 31" Model A spring pack. The trick is that the wishbones angle in and that makes up the width difference between the earlier Model A axle and the '41 axle. Getting those perch pins out is a real PITA, and mine wasn't as rusted. I think you got a killer deal on all of the frame components for your '27. Did you get the flathead as well, or is it missing?
No motor or trans, that would have been an insane deal if they where there. I'm going to start soaking the parts in PB Blaster. I'm sure she can soak for a few weeks before I give it a go and try to unbolt everything. Fingers crossed for that day. I've read up a bit on the perch on bones setup. Could work for me but I need to draw it all out. I am trying to keep wheelbase small but have enough room for everything too. Lots of 26-27 T roadsters end up too long after you stuff a big motor in them.
The best way to stay away from the too-long look is to not use a Speedway Model T frame kit. I think my wheelbase will be about 108" That may be too long for some, but I want to make sure I have room for a mechanical fan in front of the engine. The oil filter also sits real close to the front crossmember at the front of the engine.
a little chop on the top some lowing and throw a nice paint job on it it would make a nice looking car but know guys who would fight for a body in that shape what we get here is nothing like that
I still think that would be a good family street rod candidate. Heck, the door handles are already halfway to shaved! There's a lot less hours removing parts involved in selling the frame and body too!
