What to use to give the sandcast look
Discussion in 'The Hokey Ass Message Board' started by WILTBILT13, Apr 18, 2012.
  1. WILTBILT13
    WILTBILT13
    Have a couple pieces of aluminum was wondering what everybody is using to blast them to give the best sandcast look?
  2. dorf
    dorf
    from ohio
    sandblast em or bead plast em
  3. chaddilac
    chaddilac
    Yep!!! Only sand can give that look!
  4. swissmike
    swissmike
    A pneumatic scaler can also give you a pseudo finish. Maybe combine with the sandblasting.
  5. 28 jalopy
    28 jalopy
    from arizona
    I have used sand on T6061 billet I have machined to give the cast look. It turns out nice,and a light hit with light grit sandpaper to give a past polish look.
  6. bobss396
    bobss396
    I saw a guy p*** off his aluminum aftermarket intake manifold as a cast iron item. This was on a stock car, bending the rules a tad. The trick was to mix up some brake drum shavings in a quart of Chevy orange paint and slap it on the manifold.
    Apply more shavings when it was still wet, let it dry and give it another coat of paint. Didn't look bad and was supposed to p*** the "magnet" test.
    Bob
  7. Sand blasting and quick scuff to remove the high rough ridges will give you the surface texture.
    A sand cast part has characteristics all of its own, there is no dead flat or square areas unless it was machined after, every surface has some draft to it.
  8. oldolds
    oldolds
    Sandblast then clear. Looks a little different, but easy to clean. Won't stain.
  9. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Gl*** bead-blast. Thats what I use on vintage motorcycle engine/trans cases.
  10. Dale Fairfax
    Dale Fairfax
    Agree with the "sand blast" but not the "Bead blast". Sand is co**** enought to replicate the sand cast look but all gl*** beads to is give everthing a satin finish. Sand will knock down corners and erode weld beads-gl*** won't.
  11. williebill
    williebill
    A kid who works for me had his aluminum bicycle frame sandblasted. He used a powdercoater who has a big blaster,running at a pretty high pressure,co**** sand,etc. Left the tubes pretty rough,and it looks like it was cast now.
  12. Atwater Mike
    Atwater Mike
  13. BHT8BALL
    BHT8BALL
    Started with a billet piece, after co**** sand blast it was soda blasted to knock down the sharp peaks, then primered & painted. P
  14. Ricci32
    Ricci32
    I have used a hammer and sand paper to finish a repair on a triumph motorcycle case the trick was giveen to me by a old bike restorer. worked fantastic different course paper for the correct finish.
  15. Kind of like a texture stamp, I'm going to have to try that.
