what to use to seal drip rails?
Discussion in 'The Hokey Ass Message Board' started by peter schmidt, Jun 18, 2012.
  1. peter schmidt
    peter schmidt
    from maryland
    Just cleaned out the sealant stuff from my rusty driprails on the falcon it was all shrunk up and holding water / dirt in the cracks. What do you guys use to seal these back up? I have seam sealer but it never seems to go on smooth. Any help or tips appreciated
  2. pimpin paint
    pimpin paint
    from so cal
    Hey,
    A product called Eveico seam sealer has been the standard for over fifty years. DON'T use anything with silcone in it!:eek:
    " Do not reach greedily for the Kool-Aid "
  3. Gary in da UP
    Gary in da UP
    3M Drip check sealer
  4. Beau
    Beau
    Most body shop supply stores should have seam sealers on the shelf. I think NAPA had the cheapest at around $12 if I remember right, but it might not be the best. Most tubes cost around $40.
  5. 296 V8
    296 V8
    from Nor~Cal
    Seam sealer ……… get it at the auto paint store
  6. Bugguts
    Bugguts
    I have always used 3M seam sealer. I wet my finger in grease and wax remover to smooth the sealer to perfection. Make sure the sealer is paintable and yes, do not use anything with silicone in it, you will hate yourself for it.
  7. Gary in da UP
    Gary in da UP
    Good drip check sealers don't require tooling or smoothing.... they flow so if you have a steep slope use sparingly and make a dam out of masking tape to stop the runs if you use too much.
