What will cause this?
Discussion in 'The Hokey Ass Message Board' started by bowtiemyk, Jan 18, 2013.
  1. bowtiemyk
    bowtiemyk
    What will cause this to happen? This is the second time this has happened, two different vehicles, two different distributors, same module used in both units. Will the module cause this? The module is a MSD Rev limiter.
  2. derpr
    derpr
    why does it happens
  3. Mr48chev
    Cause what? You didn't give any description of the problem and we can't read minds.
    If you are blowing modules it's most likely due to another problem such as a coil or secondary wiring issue. If you didn't use the dialectric grease on the back of the module to help transfer the heat away that may be the problem. Provided the module is in the distributor.
  4. derpr
    derpr
    it keeps going and going
  5. bowtiemyk
    bowtiemyk
  6. bowtiemyk
    bowtiemyk
    sorry, image didn't upload. I have burnt 2 caps and rotors.
  7. derpr
    derpr
    nice pic. yes a module will do that. very common
  8. bowtiemyk
    bowtiemyk
  9. auto shop
    auto shop
    from kentucky
    Check your engine grounds also.
  10. landseaandair
    landseaandair
    from phoenix
    Are the distributors OEM or imports? I've seen at least one of the latter that had issues with rotor height. Could be too high and damaging the carbon as the shaft moves up when cam gear starts too turn or too far down from the start and arcing?
  11. rotor too close to the cap
    actually the root of your problem is MSD
  12. Gus68
    Gus68
    from Minnesota
    I belive there is a low resistance button to replace the "stockish" one you keep burning up. Might wanna check MSD.
  13. Why would a module cause that? I be thinking too damn many volts, but hell, those are the high di-electric caps and rotors!
  14. SanDiegoHighwayman
    SanDiegoHighwayman
    put some clear dielectric grease on the rotor tip where it touches the cap button? "jist a dab'll do it" "use more only if you dare" :D
    [ old brillecreme ad slogan:rolleyes: ]
  15. excessive sparkplug gap will burn up a cap quick.its happened to me.run stock gap on the street.
