Customs What will clean this?
Discussion in 'The Hokey Ass Message Board' started by Thunder Road, Sep 15, 2023.
  1. Thunder Road
    Thunder Road
    Anyone have an idea what I could use to turn the intake back to aluminum color?
  2. Clydesdale
    Clydesdale
    vapour blasting
    dana barlow and '28phonebooth like this.
  3. saltflats
    saltflats
    from Missouri
    Etching mag wheel cleaner.
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    Good old carb cleaner and a rag.
    Deuces, slayer, Desoto291Hemi and 5 others like this.
  5. Bandit Billy
    Bandit Billy
    Aluminum spray paint. Brush it on.
    bobss396 likes this.
  6. evintho
    evintho
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What intake problem? All I see is blue stuff that don’t belong.
    Deuces, winduptoy, Bob Lowry and 10 others like this.
  8. DDDenny
    I finally found something more cringe worthy than the silver flexible radiator hoses.
    I think I would have removed that before taking the photo.
    slayer, Bob Lowry, da34guy and 4 others like this.
  9. Hideous really
    Bob Lowry and da34guy like this.
  10. BCM191
    BCM191
    from NW Indiana
    LOL.....
    Oh Purple cleaner works good
    aircap and Tman like this.
  11. carbking
    carbking
    Like others who have posted, I don't care for the Skittles look; but it is your vehicle.
    As to your question, Dawn Power Cleaner in the spray bottle, let set a few minutes, then paper towels and elbow grease.
    Jon
  12. Napa sells an "Aluminum Brightener" in a spray bottle that works well. Acid Based. Spray on let it do its work, spray it off with a garden hose!
    Deuces likes this.
  13. Thunder Road
    Thunder Road
  14. winr
    winr
    from Texas
    I tried a bunch of different things ... the aluminum intake would start oxidizing ( white powdery looking )
    Took off the air cleaner and covered the carb, distributor and such
    Mixed up some Meguirs car wash quad strength in real hot water and used large bristle brush made to wash cars
    and scrubbed the intake
    Rinsed the intake off and dried it with cloth ..... still looks ok after a year
    Ricky.
    2OLD2FAST likes this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Run what you want, I don’t care but which part of what this board believes in do you not understand?
    slayer, CSPIDY, Rickybop and 2 others like this.
  16. Rex_A_Lott
    Rex_A_Lott
    The acid based wheel and grille cleaner will clean it up to look like bare aluminum, but be aware it will dull the piss out of anything shiny it touches, including powder coated wheels and other stuff. To do a really good job, you would need to remove it and have it bead blasted. Good Luck.
    MMM1693 likes this.
  17. Torana68
    Torana68
    from Australia
    Black leads and hoses will clean that up a lot, try degreaser in inlet before you try stronger stuff. If it really really bugs you take it off and get some sort of ceramic coating in an aluminium clouur and you won’t need to touch tilt again
  18. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The part where the the progression of fix-up innovations were
    ( As Goldielocks would say not
    too little, not too much )
    'Were Just Right', by the year 1965
    After that year the design and devopment engineers had too many conflicting influencers to answer to..
    That we want to represent the decades of slide rule engineering.
    To avoid the unsynthesized styles, that led us to a world of baked bean body styles.
    Apologies if not caring is your take. To me it ( vintage ) is all that counts.
    CSPIDY likes this.
  19. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Fix all the gas drips first.
    Since you are all into polished aluminum and chrome, just go and replace it with one of those Chrome intakes and not have to deal with the aluminum one.
    Deuces, 2Blue2, 5window and 2 others like this.
  20. JD Miller
    JD Miller
  21. 05snopro440
    05snopro440
    I gl*** bead blasted mine then clear coated it. Worked great.
    That was when I had the intake off to get the heads done.
    rockable likes this.
  22. :rolleyes::rolleyes:
  23. Marty Strode
    Marty Strode
    Doug, I have been saving some of the silver ones for you !
  24. X38
    X38
    My first thought.
    It does appear to be a lot of fuel residue/staining. Try wax and grease remover. Maybe lacquer thinner.
  25. inthweedz
    inthweedz
    Spray on oven cleaner..
  26. da34guy
    da34guy
    Keep the hood closed = Problem solved
  27. Budget36
    Budget36
    My guess is you want to clean it in place? Kinda takes a few suggestions off the table.
    But my question is what intake are you using? I can’t recall seeing one with such pronounced runners before. The Torker I had on my BBC ( but been over 40 years ago) didn’t look so rounded? If that’s the right term, as yours do.
    Just curious:)
  28. Rickybop
    Rickybop
    New rules for the hamb.
    Post whatever you want.
    A Volkswagen powered Mustang with fat tires.
    If anybody says anything about it, just pull out the old
    "Good thing I built it for me and not for you."
    Fixes everything.
    2Blue2 and CSPIDY like this.
  29. Budget36
    Budget36
    The OP is asking about cleaning the intake, has had some good suggestions as well as critiques-to be expected, but no reason to pile on.
  30. winduptoy
    winduptoy
    acetone
    Deuces and X38 like this.
