what windshield is this?
Discussion in 'The Hokey Ass Message Board' started by Paul, May 21, 2004.
  1. Paul
    Paul
    Editor
    cause the guy I bought it from didn't know and it's not what I thought it was..
    before I perform major surgery upon it, I would like to know.
    also if some one has what I need and this is what they need maybe I won't have to cut it up..
    Paul
    front;
  2. Paul
    Paul
    Editor
    back;
  3. Paul
    Paul
    Editor
    driver's side;
  4. looks like the windshield posts off of my 26 Touring
  5. Paul
    Paul
    Editor
    is there a difference between the '26 and '27?
  6. Suppose to be identical.
  7. Jojo
    Jojo
    It also looks like the early 20's Dodge. Although the mounting brackets on the bottom are different than my '23 roadster...
  8. Paul
    Paul
    Editor
    stoggie,
    that's what I thought, and I also thought that's what it was.
    it does not fit my cowl, at least not at the bolt hole location,
    it fits the contours about four inches forward of where it should attach.
  9. I think it would be Dodge now. This is a much better photo of how the post intersects the mounting plate. There is another that is close but it escapes me at the moment.
    Cut the ***** apart, lay it back 37 or so degress and mold it to the cowl. [​IMG]
  10. Paul
    Paul
    Editor
    consider it done [​IMG]
  11. now you got any extra door?? Needing some front doors for my touring. The ones I have are not nearly as good as I thought. [​IMG]
  12. Nimrod
    Nimrod
    I've heard '27 chevy posts are very similar to the fords. One bolt hole will be slightly off, and I think they are pointier than the fords at the bottom.
  13. dondanno
    dondanno
    Nimrod is correct 27 Chevy. the post is also square where the ford is round...Danny
  14. Paul
    Paul
    Editor
    doesn't look like any picture of a '27 Chevy I can find, the '27 had a very short lower gl***,
  15. Paul
    Paul
    Editor
    it does look like windshield in this picture of a '24 Chevy though...
  16. dondanno
    dondanno
    ok they are chevy none the less..They still look good and its nice you have all the pieces....
  17. The37Kid
    The37Kid
    The windshield looks like a Chevy item to me.There are differances in 1926 & 1927 Ford posts, has to do with the shape of the base, or maybe the three bolt hole placement. Once you get into 26-27 T's there are A LOT of differances, cowl,doors and back section. If you are puting a tub together from pieces you'll find this out. I need a doorless front half of a 1927.
  18. LUSK
    LUSK
    CHEVY ! The are always listed on Ebay as 26 27 ford. I almost bought some back before I knew .
