Technical What would be the "era correct" intake for a SBC?
Discussion in 'The Hokey Ass Message Board' started by deto, Aug 15, 2014.
  1. deto
    deto
    I wanted to run an exotic intake on my SBC (think 6 94's) but that's out of the budget.
    So my question is what would be a correct aluminum intake manifold and carb if I wanted to keep everything pre '62?
    The motor makes 380 HP so I'm trying to find something that will look the part and not kill performance too much...
    1Nimrod likes this.
  2. squirrel
    A C3B is probably a good compromise.
    1Nimrod likes this.
  3. coilover
    coilover
    from Texas
    Two four intake with dual WCFB carbs available from 1956 on---bring a heavy billfold.
    1Nimrod and loudbang like this.
  4. Docfranknstein
    Docfranknstein
    Tri-power, looks good , works well & won't break the bank. Von Doc
    1Nimrod and slammed like this.
  5. tubman
    tubman
    Man-a-fre!
    1Nimrod, loudbang and Hotrodmyk like this.
  6. deto
    deto
    I had a C3B on a sbc years ago. Might have to revisit that one.
    Would a tri-power move enough air and fuel to support that level of hp?
    1Nimrod likes this.
  7. deto
    deto
    I just checked them. If I could I would...
    1Nimrod likes this.
  8. mgtstumpy
    mgtstumpy
    My old C67 6x2 Edelbrock log manifold updated to X1 6x2 Edelbrock crossram. 6X2......jpg 6x2 with stack.jpg d and
    1Nimrod likes this.
  9. Dooley
    Dooley
    from Buffalo NY
    Edelbrock C4B was out before the C3B, C3B is a little better performance wise...someone here did a comparison.
    1Nimrod likes this.
  10. bowie
    bowie
    A 1962 Corvette 327/340 hp aluminum would be a good choice.
    1Nimrod likes this.
  11. kreits with any variation of multiple carbs. Offy 2x4 with a pair of little carters or rochesters (4 jets).
    Or if you got the gonads and the skills to pull it off a pair of crudly constructed sheet metal manifolds( yea a pair) like *these on my old ChetSmith 394 olds. ;)
    Cheap to build for sure.
    *of course they are crusty, they have been under bench for nearly 60 years. :D:D
    1Nimrod likes this.
  12. deto
    deto
    1Nimrod likes this.
  13. deto
    deto
    PNB, I have both of those. My day job is at a precision sheet metal shop as a production engineer. Maybe I could do a manifold. But would it run well? That's my concern.
    1Nimrod likes this.
  14. Cantstop
    Cantstop
    probably anything with the oil fill tube will keep the wolves at bay.....just dont run a Demon
    1Nimrod likes this.
  15. RICH B
    RICH B
    Look kinda electrical to me.
  16. need louvers ?
    need louvers ?
    Completely self serving, but I have about the nicest C4B that I have ever held in my hands on E-Bay at the moment. That and an Edelbrock carb with the stupid tag removed and possibly dulled down a bit with some "Super Clean" type spray cleaner would probably do the trick quite nicely.
    1Nimrod likes this.
  17. slowmotion
    slowmotion
    I picked up an old Edelbrock C3B with the oil fill tube at an estate auction earlier this spring. For 20 clams, it'll go on something Hamb friendly in the future.
    1Nimrod likes this.
  18. blue 49
    blue 49
    from Iowa
    My swap meet C3B was $60.
    Blue
    1Nimrod likes this.
  19. _CAM6325.jpg What about a Fenton?
    1Nimrod likes this.
  20. mgtstumpy
    mgtstumpy
    1Nimrod likes this.
  21. enloe
    enloe
    from east , tn.
    That was some good info
    1Nimrod likes this.
  22. mgtstumpy
    mgtstumpy
    OT old Mooneyes style EFI hidden in faux 97's :eek::eek: Not traditional I know however I wanted tune ability, economy and reliability given the price of gas down here.Work in progress as I plan on putting on the miles in future.
    1Nimrod likes this.
  23. deto
    deto
    So the edelbrock style carb is correct for that era?
  24. deto
    deto
    Wow that looks *****in
  25. need louvers ?
    need louvers ?
    Ya, you'll get lots of dissenting votes around here, but the honest to god truth is that the Edelbrock carb is basically the same thing as the old Carter AFB of the late fifties and early sixties. The biggies that the true traditionalists don't like is the bright red EDELBROCK name plate right below the air horn, and the new style tumble polish type finish. The name plate removes with about 17 seconds worth of carnage with a pair of small needle nose pliers, and the Chromey kinda look can very quickly be dulled by using a cleaner such as Super Clean that doesn't like polished aluminum in small doses.
    1Nimrod likes this.
  26. belair
    belair
    Brad54
    1Nimrod likes this.
  27. deto
    deto
    I think this is a good option. I like edelbrock carbs for their tunability and the fact that you can buy parts for them at chain auto parts stores. I also loke the idea of de-shining them...
    1Nimrod likes this.
  28. falcongeorge
    falcongeorge
    from BC
    Not really, unless you insist on the correct Corvette carbs. I'm in the midst of piecing the whole ****erree together right now, including 9 fins. Not as cheap as a performer rpm and eldeebroke afb, but not as much as a OL496 and carbs...;):D
    enloe likes this.
  29. falcongeorge
    falcongeorge
    from BC
    Yup, C355B and three rochesters is cheaper than the corvette intake and 2 wcfbs by a large margin, and works good, properly set up will outperform the c4b and afb combo.
  30. squirrel
    You can do a little work and get it close. This is a "modern" AFB, made by Weber with the Carter name in the 90s.
    1Nimrod likes this.
