Technical What would happen if you simply didn’t break in a flat tappet cam?
Discussion in 'The Hokey Ass Message Board' started by KEVIN SODERBLOM, Jun 28, 2020.
Tags:
  1. Budget36
    Budget36
    Cool thing! Been wondering about that for 25 years or so:)
  2. Boneyard51
    Boneyard51
    SO what's your additive?[/QUOTE]
    Power up is the additive I use.
    Bones
  3. jose55
    jose55
    Hi, im currently installing on my project a 350 sbc, new cam, new lifter, rod and main bearing, i was doing the break-in process and the radiator went bad and had to shut off the engine, it only ran for 5 minutes in 1800 - 2000 rpm, now i have a new radiator and is already installed on it, what would be the best recommendation to continue with the break-in after 2 month the engine is sitting? just start it and bring it up to 2000 rpm again?
  4. big john d
    big john d
    from ma
    comp cams has a tool to cut a small groove in the lifter bore to supply oil under pressure directly onto the cam lobe surface just before it starts lifting the lifter part number 5002
  5. speedshifter
    speedshifter
    I wonder if it is as important to have engine with new cam & lifters start running immediately. Prior to this start, have engine timed absolutely correct & carb bowel full of fuel, also prime oil system. Do this & keep engine above idle speed & I believe you will minimize your problems. speedshifter Greg White
