Technical What would Johnny hamber do?
Discussion in 'The Hokey Ass Message Board' started by silent rick, Jan 4, 2024.
  1. oldiron 440
    oldiron 440
    I had a customer who had a 55 or 56 Ford that would puff perfect rings at idle out the draft tube. New valve seals fixed him up but it sure was comical…
    AHotRod likes this.
  2. Marty Strode
    Marty Strode
    I used a PCV on this Dodge. I drilled and tapped the intake 3/8 pipe on the bottom side. Installed a br*** 3/8 pipe to 3/8 inverted flare 90 fitting, and bent a 3/8 steel line to run from the fitting to a grommet holding the valve, in the road draft tube. Since it was a 241, I used a valve from a 240 Ford six. In this photo, you can see the steel line running under the intake. P1010074.JPG
  3. Bandit Billy
    Bandit Billy
    You do good work Marty. I don't care what the others say.
  4. Marty Strode
    Marty Strode
    Thanks Bill, you are one of the nicer guys !
    Bandit Billy likes this.
  5. DDDenny
    Darn few left too!
    Lost in the Fifties likes this.
