What would look good in the grill of the Fly?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Nov 15, 2003.
  1. atch
    atch
    why does that always happen? i've got the perfect solution, and two minutes before i'm gonna answer someone (happens to be boones this time) takes the words right outta my mug?
    MOON TANK!
  2. Roothawg
    Roothawg
    I have a tank that is a vertical one that is mounted on the left if the frame. I hoped it would fit in the opening but it looked wrong and was too cumbersome to route all the hoses. That's what I had in mind originally.
  3. Revhead
    Revhead
    from Dallas, TX
    Some WWII style teeth (like p-40 warhawk nose art)drawn on either a panel, or just cut out at the tops and bottom.
  4. Blue Plex....drilled with Barnett Designet Draginfly.
    But having said that..it's stilll perfect as is....
    Cheers
    MAIKI [​IMG]
  5. delaware george
    delaware george
    from camden, de
    i like it,but i like the blue plexi idea also
  6. Roothawg
    Roothawg
    The only problem with that is I would hafta buy another freaking sheet!!!! Won't sell me just a little piece. [​IMG]
  7. FLAT-TOP BOB
    FLAT-TOP BOB
    HAMB O'dex Editor
    how bout the plexi with a alum. panel behind it with the drag/n fly painted on it!
  8. 201
    201
    A set of Dagmars, cast aluminum, the 38 inch size,or the blue plexiglass !!!!
  9. delaware george
    delaware george
    from camden, de
    nobody has a scrap that big lying around?....maybe you could just duct tape pin-up calanders to it like dean moon [​IMG]
  10. Sam F.
    Sam F.
    i like the blue plexi idea with something cool on it like a dragon fly.
    or fill it with a polished sheet of stainless(or aluminum) drilled out
  11. kustombuilder
    kustombuilder
    from Novi, MI
    how about a RADIATOR???
    seriously. how abouts a big ole metal dragon fly that touches the top, bottom and each side. any metal sculpter/artist out there???? bet JEEM could do it. JEEM can do ANYTHING!! [​IMG] i'd like to try it but with my luck i'd get it done and someone else would have already finished one for ya. i'm kinda slow [​IMG]
  12. kustombuilder
    kustombuilder
    from Novi, MI
    [ QUOTE ]
    For a touch of whimsy . . .
    . . . a large painted zipper about one-third open.
    [/ QUOTE ]
    HELL YES!!! [​IMG]
  13. Get the grille shell down for a good hood line.
    Fill the grille with a louvered aluminum insert.
    Put a hood top on it.
    Leave the sides open.
    Alternatively, use a hole saw to put a bunch of holes in the aluminum insert.
    Whether louvers or holes, some kind of artistic work on the hood top would work well.
    Something a little - genuine - Von Dutch or even Roth.
    The car as it sits is just about there vis a vis the 50's - 60's drag racing sedan look.
    Just needs a touch of tweaking.
  14. Roothawg
    Roothawg
    Yeah it needs something....just can't pinpoint it.
  15. Rocky
    Rocky
    Classified Editor
    Here........this is "racier' and it looks spectacular!
  16. Shiva69
    Shiva69
    ok here is my idea.
    get a sheet of aluminum and put a grid of 3/4 to 1" holes in it starting at the corners down from the top.
    In that place above the grid of holes. you need a simple design..... and here is my last idea.
    get on of the HAMB artists to draw you a small... you decide how large.... dragonfly cartoony or otherwise. then trace it out on a appropriate size of plexy and cut it out then use a dremel or the like and add the small details.
    Then mount it w/ screws or the like.
    Garth
  17. 41sled
    41sled
    from Orange, CA
    some thing like this?
  18. kustombuilder
    kustombuilder
    from Novi, MI
    [ QUOTE ]
    [/ QUOTE ]
    best idea yet IMHO!!!
  19. shoebox72
    shoebox72
    Man, it looks good the way it is. OR A big flyswatter....
    A few strips of flypaper? [​IMG]
    Billy
  20. zibo
    zibo
    from dago ca
    how about one of those crying baby things...
  21. FEDER
    FEDER
    A FLY HOLDIN A 10 SECOND ET SLIP!!! Forget about the grill make it run First.--FEDER
  22. no hood is my vote..gives the fly that more 'hardkore(tm) look...hood makes it too "normal'" imho.
  23. BLAKE
    BLAKE
    Red plexi grill...
  24. BLAKE
    BLAKE
    Holey aluminum/mesh (Batman!)...
  25. Roothawg
    Roothawg
    You guys have waaaaay too much time on your hands..... [​IMG]
  26. BLAKE
    BLAKE
    The web thang...
  27. BLAKE
    BLAKE
    Da moon tank...
  28. BLAKE
    BLAKE
    D'oh! Da moon tank, redux...
  29. BLAKE
    BLAKE
    Just shortened the shell...
  30. Sailor
    Sailor
    Either: Blue plexiglass with silver pinstriping.
    Or: an aluminium insert with a weirdo style painting on it done in orange and black.
