What year F-100 brakes to use??
Discussion in 'The Hokey Ass Message Board' started by RED-EYE-KUSTOMS, Nov 9, 2011.
  1. RED-EYE-KUSTOMS
    RED-EYE-KUSTOMS
    from CA
    Currently collecting parts for my 30 coupe build. Just found a rear & moving to the front. What years from the F-100's (front brakes) would be compatible with a dropped axle/wish bone set up with '40 ford spindles?
    Thanx
  2. rockfish
    rockfish
    I'm using '53 F100 brakes on my '40 spindles. 48-52 F1 and 53-56 F100 brakes will work though. You'll need new bearings to adapt to the early p***enger car spindles. Speedway sells the bearings as a kit or you can source them from NAPA. Be sure to change out the bearing races too. Speedway also sells a booklet on the conversion but it's really not needed. Good luck.
  3. chopt top kid
    chopt top kid
    Early Fords and the F-100 use the same outer brg. and cup. Timken 09067 brg. and Timkin 09196 cup. The F-100 spindles are larger in diameter in the area of the inner brg. than the earlier Ford spindles.
    For this swap a brg. with the smaller I.D. is required. The necessary brg. is Timkin number 14116. It has the I.D. of the earlier Ford spindle and the O.D. of the F-100 hub. The inside if the inner race must be radiused slightly to fully seat against the early spindle. The stock F-100 inner cup (Timken 14276 ) is used along with a Victor seal 49196 or National 450461.
  4. RED-EYE-KUSTOMS
    RED-EYE-KUSTOMS
    from CA
    Thanx for the info rockfish.
  5. RED-EYE-KUSTOMS
    RED-EYE-KUSTOMS
    from CA
    Thanx chop top for the #'s.
  6. dirtracer
    dirtracer
    Can you use the F100 spindles in this situation?
  7. ford1932
    ford1932
    from Canada
    Use the later f100 setup as the f1 drums if needed new are about three times the price of the later f100's
  8. RICH B
    RICH B
    F-100 spindles have a larger diameter kingpin and the angle is incorrect.
    F-1 spindles use the same kingpin as '42-'48 car and can be used. The
    left steering arm is pretty ugly; but the spindles can be trimmed to resemble
    square back car spindles and used with bolt on steering arms. Some people
    will say the angle is different; but they measure right with my digital protractor. Here are a couple of pictures of some F-1 spindle that have been
    trimmed and the grease zerks relocated to work with bolt on arms.
  9. dirtracer
    dirtracer
    If the F1 spindle is used, then which is the best backing plate and hardware? Also can you switch sides with the spindles to put the steering arm in front?
  10. RICH B
    RICH B
    '48-'56 backing plates are all alike and use the same shoes, cyls, and hardware.
    You can also use the self adjusting hardware from early '60s F-100 if you like that sort of thing.
    It is just the hub/drum ***y that are different between F-1 and F-100.
  11. dirtracer
    dirtracer
    So, can I switch the spindles to put the steering arms out front? Thanks for all the info!
  12. dirtracer
    dirtracer
    Well???????????????????????????????????????????
  13. 38Chevy454
    38Chevy454
    The ackerman will be all messed up. I am not sure if you can heat and bend the steering arms enough to make it work. Anyone know? Heating and bending using good technique is fine, I am asking about if there is enough room.
  14. RICH B
    RICH B
    There is not enough room to bend the arms outward, they will hit the backing plate well before they would be properly located for correct ackerman.
    A car with the tie rod out front looks like somebody took a short-cut when they were building it. Just saying.
  15. dirtracer
    dirtracer
    If the ackerman is not correct, what are the consequences?
  16. chopt top kid
    chopt top kid
    Front tire scrub, depending on which one gets the most traction will determine which one scrubs and which one steers. The principles of ackerman determine that when a car steers around a curve, the inside wheel steers around the inside of the curve and the outside wheel steers around the outside of the curve. When the ackerman is incorrect, the front wheels try to either steer toward each other or steer away from each other similar to a toe in condition or a toe out condition. Besides premature tire wear, the front end can dart around while steering around a curve depending on which tire is gripping the road and which tire is slipping...
  17. HomemadeHardtop57
    HomemadeHardtop57
    use your ford roundback spindles and either 49-53 truck brakes..11inch backing plate
    or early ford 3/4 ton pickup front brakes..same as above but with a 12 inch backing plate for running buick drums.
    You can get all the parts..shoes.wheel cylinders...etc right from your local parts house..auto zone..etc.. because they are bendix style adjusting brakes. Lots of info here about them if you do a search..some threads even have part numbers for the brake parts too.
    You can get a new bearing and seal kit from Speedway as mentioned above
  18. HomemadeHardtop57
    HomemadeHardtop57
    no..you have to heat and bend them forward if you want to do that
  19. dirtracer
    dirtracer
    If I leave the spindles where they are, clean them up and add bolt on steering arms pointed to the front, will I still have ackerman problems?
  20. curbspeed
    curbspeed
    The answer is yes. I have some 56 F-100 drums and backing plates I would sell if you need them. Pm me for details
  21. Scott
    Scott
  22. ROADSTER1927
    ROADSTER1927
    ANY tie rod in front will not handle right.Gary
  23. When did the self energizing start, and will they fit '32-'34 spindles with the right bearings?
  24. RICH B
    RICH B
    F-100 brakes will fit the '32-'34 spindles. You will need to use one of the spacer & ring kits as used when adapting '39-'48 Lockheed brakes, and deal with bolt holes via your preferred method. The bearings are the same as used with F-1/F-100 brakes on the later Ford spindles.
    Real hot rods don't need self adjusting brakes, their owners are attentive to their maintenance.
    Otherwise, self adjusters started in '64 or so. H2541 & H2540 kits.
  25. Fenders
    Fenders
    He would want the hubs also.
  26. langy
    langy
    If you put the steering arms in front the ackermann angle will be wrong.
  27. Are they only self adjusting, or self energizing as well?
  28. RICH B
    RICH B
    The Bendix brakes have always been "self-energizing". "Self-adjusting" is just a feature
    that was added later.
