what year is my olds engine
Discussion in 'The Hokey Ass Message Board' started by anton, Oct 27, 2005.
  1. anton
    anton
    can anyone help to identify my olds engine?
    Casting # on engine 567405
    Casting on heads 567322 and a big "10" above exhaust ports
    deck # V1 310451
    anton
  2. praisethelowered
    praisethelowered
    #10 heads are the ones you want. . . mine are 1956 . . . that's probavby what the first two numbers of the block number mean as well.
    Congrats you got bigger ports!
  3. OldsGuy
    OldsGuy
    I have a reference at home I will check, I think it gives engine ID info for each year. For the later years (60's 70's) Oldsmobile ID'd their heads with numbers for the small blocks and numbers for the big blocks, maybe they were using the same scheme back in the 50's as well. I think the numbers were 5,6, and 7 with variations, the leters were B,C,D,E,J etc...
    If my reference doesn't work, I can post this question on an Oldsmobile site I go to sometimes, they will be sure to know....
  4. anton
    anton
    thanks,
    someone told me it is a 1954 engine according to the deck #. while the heads are from 56?
    anton
  5. mine starts with 56 aswell i also thought it meant the year but i was told otherwise. mine has the number 8 on the heads which means its a 55. unless the heads were changed of course... dont hold me to this but i THINK 10 would indicate 57,i could be wrong i tried to look up the post i made but couldnt find it. im pretty sure he said 10 was 57....if it is. anyways, good luck with that
  6. yorgatron
    yorgatron
    block is '56,so are the heads.
  7. OldsGuy
    OldsGuy
    Anton, my reference agrees with yorgatron. Your engine is '56 vintage from an 88 car
    "Cast-iron overhead valve V-8 engine. bore and stroke: 3-7/8 x 3-7/16 inches. 324 cid. Hyd valve lifters. cr 9.25:1. Hp 230 @ 4400 rpm. Torque: 340 lb/ft @ 2400rpm. Rochester 2GC carb. Optional engine for the Super 88 was the same except for 240 Hp @ 440rpm. 350 lb/ft @ 2400rpm. Rochester 4GC carb. I wouldn't be afraid to guess the cam grind MIGHT have been a little more agressive.
    Hope this helps out.
    Dan
  8. anton
    anton
    Did you check the engine/deck number???
  9. RocketDaemon
    RocketDaemon
    from Sweden
    #10 heads, nice nice, got 2 pair of 324 heads but no #10's
    #10's are gooood!
  10. OldsGuy
    OldsGuy
    No the book didn't list the deck numbers,but on the casting number on the engine the 56 indicates the year, the 7 indicates an '88 engine, the 9 would indicate a '98 engine. Sorry.
  11. RoyalCrown32
    RoyalCrown32
    Thats odd. The casting# of my Rocket is 561747 and the deck# is R288580. According to the info I got my engine is a 303 from 1953.
    Richard
  12. anton
    anton
    Does anyone know the diameter of the camshaft journals? I think they changed it for the 1956 engines.
  13. DON_WOW
    DON_WOW
    Block id v1310451 is a 1954 block heads are 1956 cam journal size is small 1.8724--29
  14. anton
    anton
  15. anton
    anton
    Don_Wow
    According to the engine# I have a 1954 block. I have measured the Cam journals they measure 1.99645 So that looks to be a 56???
  16. DON_WOW
    DON_WOW
    1954 engine ID NUMBER on deck outside of number 5 cylinder hole ...third one back from front ,drivers side is V1001 TO V355083.
    1956 engine ID is A001001 TO A385513.
    If cam journal is 1.9977-1.9985 has to be a 56....don't know why
    gonzo likes this.
