History What year is this Ford chassis?
Discussion in 'The Hokey Ass Message Board' started by 65standard, Aug 10, 2020.
  1. 65standard
    65standard
    I’m asking because I’m having a hard time getting the clutch pedal and linkage to line up? I think I have a mixed bag of different year parts. I’m guessing 1941 AB25E1E8-FFDD-44EA-947E-5E1A425519A9.jpeg
  2. That’s my final answer
    dana barlow likes this.
  3. 65standard
    65standard
    69A7313E-56A4-4451-AA92-B13CE49DE6CF.jpeg The front axle specs out as a ‘37-‘41
    38 1/2” wishbone center
    48 1/2” spindle centers.
  4. 65standard
    65standard
    It must be a hodgepodge of parts.
    anthony myrick likes this.
  5. millersgarage
    millersgarage
  6. Tim
    Tim
    from KCMO
    Can we see the brake backing plates? Could help
  7. Looks to have the correct wishbone with the spring in front. Do you have a pic of the axle ends?
  8. The37Kid
    The37Kid
    Never seen one that new, must be 1946-48. What is the deal with the rear spring? Bob
  9. Possible on the 41. I forget the interruption of WW2.
    Here is a side shot of a 41. Maybe it can help. Not aware of the subtle differences between the years.
    Any numbers on it?
  10. badshifter
    badshifter
  11. King ford
    King ford
    from 08302
    I believe that front crossmember is for a straight 6 , also that looks like a pickup battery box on the RH frame rail...42-47 pickups had 4 parallel leaf springs so I'm guessing 1941 pickup....
  12. 65standard
    65standard
    Here’s the front axle
  13. seb fontana
    seb fontana
    from ct
    '41 would have a panhard bar and the stabilizer..Since there is only the stabilizer bar I would say 1940, first year.
    65standard likes this.
  14. Papas32
    Papas32
    from No.Ia.
    i agree with KingFord ., also still has transverse springs, six cylinder crossmember and no body mounts on sides of the frame. has to be 41 p.u.
  15. Would a truck have a gas tank on the back?
    was it added?
  16. Bandit Billy
    Bandit Billy
    It would in 40-41 the 46 had it under the seat by that point.
    kidcampbell71 likes this.
  17. Well alltighty
    Didn’t know that
    Cool
  18. 40FORDPU
    40FORDPU
    Appears to have brackets on the outside of the frame just before the rear wheels, p/u's didn't have those.
    I've never seen a p/u with a ribbed gas tank.
    BB's right about the gas tank locations.
    Bandit Billy likes this.
  19. Marty Strode
    Marty Strode
    It's a p***enger car ch***is, 41 or 42-48. All 35 to 40, along with 41 PU, had the doubled frame "gloved" as shown. The later car ch***is had the reinforcement, installed as a box. IMG_4363.JPG
    kidcampbell71, X38 and Bandit Billy like this.
  20. Bandit Billy
    Bandit Billy
    Marty, you clever fella. You "stood up" that rear crossmember. I have never seen that done before. I cut mine out and replaced it, I like yours better. Clever Marty.
  21. Papas32
    Papas32
    from No.Ia.
    your right Marty! I completely spaced out over the frame difference.
  22. 1946caddy
    1946caddy
    from washington
    Pretty easy to tell the difference.
  23. treb11
    treb11
    mgtstumpy and dana barlow like this.
  24. I’m gonna change my final answer
  25. I think you can narrow it down to '41 based on the axle. It's a different animal from the '35-'40 frames or the '41 pickup frame. The '41 pickup frame is essentially a '40 car frame minus the body mounts riveted onto the outside rails, and the 6 cylinder '41 pickups sit a little higher in the front than other '40-'41 pickups because they have a deeper front crossmember that is unique to the '41 6 cylinder pickup. Somewhere I have an old issue of Rod & Custom boxed up that has a tech article on how to use that '41 6 cylinder pickup crossmember to put a small block Ford in the '35-'40 car/'35-'41 pickup ch***is. I'm so old I can remember when car magazines ran how-to articles on doing stuff with junkyard parts. Been 50+ years since I saw a '40-'41 Ford pickup in a junkyard. I'm pretty sure you have a '41 car frame, but you can find the serial number of the vehicle stamped in 3 places on top of the left frame rail--next to the steering box, about mid-way around where the B pillar of the car would be, and on the arch over the rear axle. Check that number against the listings on Mac VanPelt's site to confirm what you have.
  26. warbird1
    warbird1
    Find the serial number and that will tell you what year the frame is...
