Technical What year rearend help
Discussion in 'Traditional Hot Rods' started by Al, Oct 29, 2023.
  1. Al
    Al
    from Duluth, Mn
    Hi. I have a Ford 8" rear end. I have had this car for 17 years now. I was told back when I bought the project that it was a 9". turns out it is a 8". I want to replace the wheel cylinders on it, but not sure what year. Are there numbers on the rear that would tell me what year, and if it came from a car or truck? thanks
  2. squirrel
    won't be a truck. There are some numbers...maybe...which may or may not be helpful. Look for casting numbers on the center section, look for a metal tag under one of the nuts that holds in the center section, and also just measure the brake shoe width, brake drum inner diameter, and wheel cylinder bore size, then look up various cars it could be from on rockauto. But also post pictures of the thing, there are some clues that some guys can see. that you can't describe.
    RICH B likes this.
  3. Since it is under your avatar car, I would venture to guess it is either Maverick or Mustang/Cougar. You can narrow it down some by measuring the drum register. Ford used a 2-3/8" register up to 73 and went to 2-3/4" afterwards. As Jim said, pictures and width would help.
  4. ClayMart
    ClayMart
    Never heard of the term "drum register" before. I would ***ume that it's the raised boss that sits proud of the face of the axle flange and fits into the center hole of the brake drum. That could also be a handy spec for finding a new brake drum for a replacement axle ***embly.
  5. The pics don't help much. Since the drums have the ribs, they are probably 10" x 1-3/4" shoes. The wheel cylinders are another matter since the early/late Mavericks, Mustangs, Cougars, etc. mostly used different wheel cylinders. Those cars also came in 9" brakes with yet different cylinders. If you can get a WMS to WMS width plus the register size we can narrow it down for you.
  6. Al
    Al
    from Duluth, Mn
    For that I will have to wait til I get the car back.
  7. V8 Bob
    V8 Bob
    I would mic the wheel cylinder's bore, then take one (or both if the line ports are angled different) to your favorite car parts store(s) and ask for that bore size in '60s/'70s Ford products rear drum brake cylinders. They will be Bendix replacement parts, as that's what Ford used on the 8/9" rears during these years.
  8. Al
    Al
    from Duluth, Mn
  9. Al
    Al
    from Duluth, Mn
    I got that from my pictures. It is also 5 on 4 1/2" bolt pattern. The front is from a Mustang II that had 4 lugs. I converted to 5 with the 5 on 4 1/2" bolt pattern.
  10. gimpyshotrods
    gimpyshotrods
    You are correct. It locates the drum or rotor concentric with the axle or hub.
    On later vehicles it also locates the wheel concentric with the axle as well.
  11. BamaMav
    BamaMav
    from Berry, AL
    Looking at that last pic, I don’t see a fill plug in the rear, so that makes it a later housing. Early rears had the plug in the housing, rears have in on the side of the third member chunk. I don’t remember right off the top of my head what year the change was made, but know by changing the chunk you could end up with two fill plugs on a early housing, and none on a later one. Like was said, center register will narrow down the axle age, but even the big register axles can be put in the earlier housing, so that’s not a definite answer, either. Only way will be to measure brake shoes, drums, and wheel cylinders to get replacements.
  12. Illustrious Hector
    Illustrious Hector
    What station wagon used an 8 inch diff ? Sounds like the car is in "paint jail" I'm guessing the college is using your car to "learn on" for a free paint job? Don't think I could do that, 3 years is a long one.
  13. Al
    Al
    from Duluth, Mn
    I pay for the materials. Not the labor. Are there numbers stamped on the wheel cylinders?
  14. Some wheel cylinders are stamped, or cast with numbers. Bore size is what you are matching up, basically, though. I often use Rockauto to find dimensions etc to match up what I have. I'll check what I think it is first, say 1975 Maverick, then work from there. They have the part numbers listed, and you can order through them or local supplier.
  15. Al
    Al
    from Duluth, Mn
  16. Al
    Al
    from Duluth, Mn
    That is a picture of the rear end back from when I bought the car.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Odds are it's a Maverick, Mustang or Comet 8" rear axle, most of the components are the same. HRP
  18. The Fairlane and Comet were available in a station wagon, as well as the Falcon. 8" in a wagon would probably be a Falcon.
  19. Al
    Al
    from Duluth, Mn
    I will go next week, and see if I can get the casting numbers off of one of them.
  20. V8 Bob
    V8 Bob
    You really need to have them in hand to match new parts.
  21. 31Apickup
    31Apickup
    Granada and Monarch rears were popular to use in 35-40 Fords with the Ch***is Engineering kits.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I removed your second post in this thread because your modern wheels and your Pinto independent front suspension are off topic and not allowed on this site....
  23. geoford41
    geoford41
    from Delaware
    mine is a Granada rear end 8" also a Monarck had 8" typicall 74-78 I believe
