Technical What year?
Discussion in 'The Hokey Ass Message Board' started by James Haram, Nov 21, 2019.
  1. James Haram
    James Haram
    When purchased my Model A it had a banjo style rear end. I don’t know anything about it I just pulled it and install a 56 bel air rear end. Can you help me identify possible year and what is worth. I also have a hood I didn’t use as well. IMG_1591.JPG IMG_1589.JPG IMG_1590.JPG
  2. Nailhead Jason
    Nailhead Jason
    that is a 1935 or 36 Banjo judging by the wishbone brackets and the drums. 35 36 had the small brackets welded to the axle bells for the wishbones to mount to. 35 has the early ford 5 on 5.5 in bolt pattern in the hubs / drums, and 36 has a wide 5 pattern. But those had mechanical brakes, this looks to have 40 backing plates and drums on it. A real good rear to have. Where are you located? Id be interested in it depending on how far you are from VA.
    big duece likes this.
  3. James Haram
    James Haram
  4. alchemy
    alchemy
    Those wishbone mounts seem to be under the tubes, not all the way around like 35-36 were.
    That is a late 32 through 34 rearend, and it's had it's spring hangers cut off the housing ends. It might be worth something for parts, but most guys intending to put it back in a 32-34 would not like the missing spring hangers.
    saltracer219 and Nailhead Jason like this.
  5. Nailhead Jason
    Nailhead Jason
    yup you are absolutely right. I see the spring hangars cut off now.
  6. Nailhead Jason
    Nailhead Jason
    if you were closer, id buy it from you just for the hubs and drums.
  7. James Haram
    James Haram
    Thanks guys, I guess I am going to tear it apart. I can use the axle tubes.
  8. Deuce Lover
    Deuce Lover
    Its 33-34.Late 32 has the radius rod brackets perpendicular to the housings.33-34 are angled.
  9. alchemy
    alchemy
    Nope. The housings with the straight brackets are the "B" style (unsupported pinion), made from the start of 32 to later, then replaced with the supported pinion style shown for the remainder of 32. Carried over thru 33-34 with the only change being length of the driveshaft and torquetube.
    When looking for the differences, the early style is recognizeable by having a round area around the pinion where the torquetube bolts on. The later 32 thru 34 style is scalloped at the TT flange, and has the angled wishbone mounting tabs.
  10. Deuce Lover
    Deuce Lover
    Interesting.I have had 1 and a seen a friends late '32 rears (scalloped torque tube end)and the brackets are straight or perpendicular to the housings.
  11. alchemy
    alchemy
    Were they in France? Maybe Ford-Europe built things differently?
    All of the round flange rears I've seen have perpendicular brackets, and all the scalloped flange rears I've seen have angled brackets. But that doesn't mean there couldn't be some crossover in there somewhere. We need David Rehor in here to set us right.
  12. rusty valley
    rusty valley
    mr lancaster would set us straight, and with some humor to go with it. sure will miss the man
    kidcampbell71 and clem like this.
  13. el Scotto
    el Scotto
    from Tracy, CA
    Bonus points for those spring mounts welded to the brake backing plates :eek:
  14. Deuce Lover
    Deuce Lover
    Hi, No not in France.Been a '32 parts hunter for 50 yrs.So far all the orig '32's here I have seen here are the Model A style rear.I am an old 1960's-70's Hot Rod USA guy retired here in France.Those rears I saw and had was when I lived in the High Desert of CA. One was entirely complete as taken out of the car. The other was complete and in parts.I even had 2 extra NOS 18- drive shafts.These late '32 rears are 8 9/16" shorter than a '33-34. I should have paid more attention to the location of where the radius rod attachment to torque tube was.David is not clear in detail his book about these rears -just that they were introduced in Sept'32 and only USA,not export models.
    kidcampbell71 likes this.
  15. clem
    clem
    Watching this for more enlightenment.
    My ‘32 sedan diff has angled brackets, and always thought and was told that it was a ‘34 rear.
    It’s a New Zealand new car.
    Now I don’t know.
  16. alchemy
    alchemy
    Well, I used to think I knew. Now I'm not so sure.
  17. FritzJr
    FritzJr
    Late '32 rears had the angled brackets. The radius rods are unique to the late '32 rears since they do not have the bend that is on the early '32 rear radius rods.
    To @James Haram : Check the gear ratio. If it is 3.54 or 3.78 (not 4.11) the center section has value. I would be interested to purchase the center section if it is 3.54 or 3.78.
  18. James Haram
    James Haram
    When I get a chance I will check gear ratio
