What's a 100 bucks....
Discussion in 'The Hokey Ass Message Board' started by Marshall Metal Shaping, Jan 24, 2011.
  1. ...and fits in a Focus wagon?
    Anybody thinking of running one of these for economy? I see on a couple of threads there are plenty of performance bits available. This was advertised, but, no one seemed interested, so, I already had a boat version with a repaired block with new internals. Who knows? they sure are neat!
  2. Nice pickup.
    My bed's not carpeted like your's.
  3. 94hoghead
    94hoghead
    Is that an "Iron Duke"?
  4. Kinky6
    Kinky6
    Mercruiser? What size?
    Kinda neat looking, though Kinky4 just doesn't have the same ring to it. ;)
    Later, Kinky6 :cool:
  5. Zerk
    Zerk
    Lance Sorchik did a big post about them, and the industrial version parts availability, maybe a month ago.
    I think they are pretty cool and have some good potential. There was a special head available on the Chevy II-based Mercruiser, and a 181ci. version.
    For economy I'd think about adapting a TBI from a GM or maybe twin SU carbs.
  6. Yes it is "The Iron Duke"
  7. squirrel
    I doubt it's an iron duke, looks like the 1960s engine, not the late 70s engine...it's made to fit the early Nova, not the Monza. note the front sump
    as far as I know the iron duke name was originated in the 70s to overcome people's fear of the aluminum lump that was used in the early vegas
  8. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I think there cool and If I had one Id run one ,You can only drive the speed limit anyway ,The only one I had was from a boat and block was cracked ,I only have chevy v8 small blocks ,Still wish I had my poncho blocks and olds ,I didnt think they would get hard to find for cheap
  9. I believe that is the misconception,as in fact the 60's example is the duke.
  10. Hi Zerk
    Do you have a link to that post?
  11. Mr48chev
    Those seem to be as rare as rooster teeth around here when a guy is out looking for one. They put 181's in a lot of Hyster forklifts though.
  12. 28hiboy
    28hiboy
    from Milton, Fl
    I like mine, can hook up to just about any GM trans. I am running a T5 with Limeworks converted shifter and ebrake handle.
  13. Very cool!
  14. 94hoghead
    94hoghead
  15. 28hiboy
    28hiboy
    from Milton, Fl
  16. willowbilly3
    willowbilly3
    from Sturgis
    I had one in a 62 Chevy II and loved it, also had a boat with one but didn't keep it long. I was at a farm auction a couple months ago and there was one, looked like it came from a swather or combine because it had a governor and an in/out clutch with belt pulley drive. I didn't stick around for it to sell.
    IIRC, the iron duke name always refers to the later 2.5.
  17. Bama Jama
    Bama Jama
    I think you are right.The Ironduke was in the Monza and Sunbirds and I think a few made their way in some early 80s Camaros.I've never seen any in the Olds (Starfire)or Buick(Skyhawk) versions. The later models had cross flow heads.S-10s and Jeeps also had them.
  18. You're right about the terminology but I think the block is very similar if not the same. The Iron Duke had a cross flow head if I recall but that may have only been the boat engine. Someone else knows for sure on that one.
  19. Red Ram Hemi
    Red Ram Hemi
    from Shack
    Iron Duke was a great peppy motor I had one in my 72 Vega GT w 4 speed!
    Mitch
  20. It seems I stand corrected! The engine is the 151 inch Poncho. The Pontiac versions block derived from the Chevy stovebolt. It is not the aluminum Vega engine.
    Always lots to learn here!
  21. David Chandler
    David Chandler
    My 85 S10 151 has a cross flow head on it. Roller cammed, and a single TBI unit. And a computer controled distributor, but I am told that the earlier HEI versions will fit it. Also the bellhousing will not bolt up to a "regular" Chevy Transmission. Metric? I checked with several transmission shops about swapping out the tranny for a TH350, and all of them said it won't fit. However I did notice Speedway now sells an adaptor to do it.
  22. bct
    bct
    151 poncho is half a 302 ....153 is 2/3 of a stove
    both have plenty of speed stuff for the average guy...super duty and merc respectivly
    when they went metric with the iron duke the bell changed?. my early 80s has a typical sbc pattern and came with t350.
  23. What's a 100 bucks....
    Im not sure but I do know she stands on the corner of an evening...............:p:rolleyes:
