whats a good, or bad clearance between your oil pan and header
Discussion in 'The Hokey Ass Message Board' started by 327Eric, Dec 20, 2012.
  1. 327Eric
    327Eric
    I'm just looking for some thoughts on this, I have a 59 ElCamino with a 427. It has a Moroso 7 quart oil pan, and ****** Super Comp headers with a 2 1/16" primary tube size. I have a little more than 1/2" clearance between th tube and the oil pan after bottoming out. This seems to close to me. should I wrap it, or keep running it?
  2. hotroddon
    hotroddon
    1/2" shouldn't cause any heat issues to speak of. Wouldn't worry about it personally
  3. Fat Hack
    Fat Hack
    from Detroit
    Ditto there!
  4. As long as there is an air gap you should be good.
  5. badshifter
    badshifter
    Any air gap is fine. But what is moving when you bottom it out? Neither pan nor header she be moving in relation to one another regardless of suspension travel.
  6. 327Eric
    327Eric
    Thanks guys. My road is so bad, when I bottom out, its on the headers. Hoping the airshocks have cured that.
  7. propwash
    propwash
    from Las Vegas
    your oil is always on the move while your engine is running, and it's getting a lot hotter in the engine than a thinwall exhaust tube is going to make it with a ½" gap.
  8. hd4unm
    hd4unm
    Put snubbers somewhere in your suspension to prevent excess travel. You won't hit the ground anymore.
