Technical What's a good seam sealer
Discussion in 'The Hokey Ass Message Board' started by blazedogs, Nov 22, 2014.
  1. blazedogs
    blazedogs
    I,ve had to do a lot of sheet metal work on my coupe.It's been mentioned before it's a good idea to put seam sealer on the back side of the newly welded seam to prevent contaminants from eventually making the seam reappear. What is a good product to use ? Gene
  2. Torana68
    Torana68
    from Australia
    Ive used the Wurth one , the other one you may not get there but its the thick grey stuff you brush on.
  3. mad mikey
    mad mikey
    The EASTWOOD COMPANY, sells some good stuff. Several different kinds I think.
  4. tb33anda3rd
    tb33anda3rd
    3m fast and firm....
  5. Dick Stevens
    Dick Stevens
    3M is what I always trust
  6. pat59
    pat59
    yup I'd go with 3M here.
    -Pat
  7. Autodave
    Autodave
    from Menifee,Ca
    Wurth, Kent, 3M. I prefer a 2 part seam sealer.
  8. I use 3m brushable it comes in a can , takes a little while to get the hang of it . It looks factory if you get it on good . On the backside of **** welds I use a good household type silicone caulk just to be sure no moisture can come thru the weld .
    tb33anda3rd likes this.
  9. loveoftiki
    loveoftiki
    from Livonia,Mi
    3M 8362 is a nice single component seam sealer you can use with a normal caulk gun. It tools out nice, you can use a acid brush , a spreader, your finger.....paintable in 30 minutes....and it can be applied directly over bare metal
  10. gimpyshotrods
    gimpyshotrods
    Haven't used anything but, in a long time.
  11. We always use 3M, most of the times we use the brushable type.
    I use a dollar store brush with the bristles trimed down to about 1in. in lenght.
    This seems to give me better control of the sealer.
    SPEEDY
    joel likes this.
