1952-59 Ford whats behind door number 1?
Discussion in 'Off Topic Hot Rods & Customs' started by Ferrell592, Nov 21, 2010.
  1. Ferrell592
    Ferrell592
    ok, there is a small plate - apprx 2in by 5in, on the top of the firewall of my 54 customline, just under the cowl, below the drivers side wiper head. This plate has 1 bolt/nut in the center. Access panel for wiper motor?? any info would be helpful. I don't want to wrench on the nut till I know whats behind it or what its connected to. I can't see what its attached to.
  2. missysdad1
    missysdad1
    Damfino! Prolly the disgrontificator adjustment nut. DON'T TOUCH IT! YOU'LL GO BLIND!
    :D:D:D
  3. Ferrell592
    Ferrell592
    well thats better than a loose nut behind the wheel
  4. LostHope
    LostHope
    that is a nut on a rod that bolts up to your steering column,dash,brake pedal/clutch mount!!!! the square plate is reinforcment the rod is for reinforcment also if anything make sure its tight!!!
  5. missysdad1
    missysdad1
    See... I tol' ya'. Disgrontificator. An' be sure it's tight!
  6. Ferrell592
    Ferrell592
    great, thank you for the info.... I was just a few days away from Unbolting it to see what was behind it.
  7. Ferrell592
    Ferrell592
    Ok, second question.... There are 2 screws, One on each side of the cowl.( drivers side/P***. side) approx. 2 inches below the bottom corner of the windshield. What are these for? I can't see up under the dash, so I don't know if they are attached to something inside the car. They don't seem to be attached to anything on the outside (except the cowl)
  8. LostHope
    LostHope
    can i get a pic? i took a 4door apart and put a 2door on the 4door frame so ive encountered almost every screw/bolt on a 54 but pics help!!
  9. LostHope
    LostHope
    if your talking about the two screws,one almost on each corner of the cowl under where the back hood corners come down? those screws are supposed to anchor down rubber bump stops for the back of the hood to rest on..:D
