what's best way to patch a tire with a screw in it
Discussion in 'The Hokey Ass Message Board' started by 49ratfink, Jun 23, 2011.
  1. 49ratfink
    49ratfink
    I usually take my tires to America's Tire and have them put on a patch from the inside. took the wheel and tire off my 61 Dodge down there a couple weeks ago and they told me they could not fix the tire because it was 10 years old.
    tire has plenty of tread and no cracking... the guy just looked at the date code and said they are not allowed to touch it.
    I seem to remember a long time ago I tried to patch a screw hole with some thing from the auto parts store .. like you ream it out and shove some rubber looking thread in there and some glue.... that one didn't work... at least for me anyways.
    what do you guys do?? :confused:
  2. LANCE-SPEED
    LANCE-SPEED
    At your local auto parts store the sell the plug kits like you mentioned, They work for me depending on how big the hole is? Did you try reading the directions?[​IMG]
  3. 2-TONED
    2-TONED
    grind the date off.
    yes a plug works great if its in the tread. ive had many MANY tires plugged that lasted for years. advance auto parts has good plugs.
  4. lvlynyrd
    lvlynyrd
    from Las Vegas
    Yeah, they worked great for me. Back in the '70's that's what we used at the Shell station I worked at. It's about ALL we used.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You're talking about a tire plug. Although some consider them the work of Satan, I've used them without issues before, including an emergency repair one cold and wet winter night with the tire still on the car. Modern tire plugs seem to work much better than the versions I remember when I worked in a garage in high school (mid '70s). There is a combination patch/plug that requires removing the tire from the rim, but it works very well. I carry a cheap plugging kit in my glovebox, and have been damned glad that I did a couple times.
  6. 39 All Ford
    39 All Ford
    from Benton AR
    Like that nonsense? Thank a lawyer....
  7. wbrw32
    wbrw32
    When all else fails...put a damn tube in it...
  8. 2-TONED
    2-TONED
    heres what you want. if you were here id plug it for you right now with the last plug i have.
      113.3 KB
  9. Crankhole
    Crankhole
    I've always had luck with the plug kits.
  10. brad chevy
    brad chevy
    If you can"t or don"t know how to plug the tire,take it to one of the smaller shops.They will patch it on the inside for you .Big shops just tell you that **** to sell you something.
  11. junk yard kid
    junk yard kid
    tire plugs kick ***. i dont care what anyone says. Ive put over ten plugs in a slit or gouge, just keep putting them in till it stops leaking. was for off highway use tho.
  12. 1320/150
    1320/150
    and, liability..... I have used plugs for years works great. Just has to be on the tread,not the sidewall!!
  13. Goozgaz
    Goozgaz
    Plugs always worked for me. Been a while but last plugged tire I had.... the tire wore out before the plug.
    Find the smallest used tire shop in you town and have them do it.
  14. DrJ
    DrJ
    You have the tire off?
    Put a good quality patch on the inside.
    If there is tearing on the inside though, any more than just a round hole where the a screw was, hang it from a tree with a rope for the kids to play on.
    I patched a Pirelli that with pressure on it had a hole the size of a cigarette back in the '60's and put it back on the rear of my MGA. I put a tube in it too.
    It let go at about 80 mph in the twisty part of 101, up between San Luis Obispo and Paso Robles I think, at 3 in the morning.
    Lucky the spare still held air even if it was bald. I slowed down after that.
    The fish-tailing was "exciting" :eek:
  15. I Drag
    I Drag
    Tighten the screw 1/2 turn.
    If you ever get a nail, hammer it in farther.
  16. Deuces
    Deuces
    I plugged a tire on my o/t pony 6 years ago.. Still no problems with it.. I use the real tacky brown "camel hair" plugs. I install those without the lube.. I did it without taking the wheel off the car.. :cool:
  17. 49ratfink
    49ratfink
    hmmm... sounds like I have been tossing 20 dollar bills into the ****per when I take my tires to have them patched.
    it was so long ago I don't even remember what car it was or what kind of tire... all I know is it did not work when I tried to plug the tire and I haven't given it another try.
    I'll have to go get one and try it again.. I'll be sure to read the instructions this time.
  18. moregsxrs
    moregsxrs
    More this:
    Than this:
  19. Atwater Mike
    Atwater Mike
    __________________
    But more than enough of this!
  20. scott 351 wins
    scott 351 wins
    i have had no luck with the little tube of glue that is provided in the kit, what i do is buy a tube of the black gasket sealer and the kit. i like the redish brown plugs better than the smaller black plugs. i ream the **** out of the hole(LOL) and squeeze a bunch of the high temp gasket sealer into the hole and apply a **** load on the plug. install the plug and i let it sit for a day than i air the tire up, i have had no leaks and still have a tire on my truck that i did this 3 yrs ago holding air with no problems.
  21. F&J
    F&J
    We used those on fleet vehicles. Incredible bonding.
    Don't know if the glue has been changed since then, but if you got just a few flakes of rubber dust in the can, then the whole can would gel.
  22. Deuces
    Deuces
    Yeah! Like a new set of tires when you don't need'em... And then on top of that, at some places they'll charge "you" the paying customer an extra 20 or so to get rid of your old ones... If they don't do that near you, give it time 'cause they sure do it here in motown.. :mad:
  23. Goztrider
    Goztrider
    from Tulsa, OK
    Exactly. Look for one of those used tire shops that have about 90% of their tires stored on racks outside. They'll patch it for typically around $10.
    This'd be what I'd do. Just depends on how hard you use the tire. If you're beating the hell out of it, it won't last at all with any sort of dry rotting or whatever on them. I have lawnmower tires that I could slide 3 fingers through the dry rot cracks in the sidewall, but the tube has lasted for 3 years now with no issues or even loss of tire pressure.
    Take it for what it's worth.
  24. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    My vote. Like the best of both....A patch and a plug. I use tire cement. No special tools required,just a drill to open up the hole(think reamer),say a 3/16, scuff area inside tire,cement and pull through with side cutters. I only use Tech,and have never had one fail. Soory no pic at this time,but if you look it up,you'll see what we're talking about.
    Now this is ONLY if the tire is dismounted! On the road,and only for emergency's it's a plug kit. The dealer-TECH SUPPLY is in the Bay Area,and tommorow,I can provide you with the contact info if needed.
    Good Hunting-Kid
  25. slayer
    slayer
    Not all tire plugs are equal. I have used Safety Seal, and Blackjack brand with great results. These are self vulcanising plugs, and dont need glue. They are stickey as hell, and do need lubricant for installation. Im not sure I would trust the cheap parts store plugs though. Tire patches are good too, and will work in some situations plugs dont, like say a 3/8 bolt stuck in a tire. On steel belted tires, plugs work better in the long run. I have seen seperated ply's caused by rusted steel belts around a patched hole. A plug would not leave the belt exposed to the elements.
  26. ironfly28
    ironfly28
    from Orange, CA
    .They don't work on bias plys but they're great on radials.......ask me how I know.
  27. hotrodA
    hotrodA
    After retiring with 35 years iin the truck tire business, I'll add my 2 cents.
    The RMA (Rubber Manufacturers ***oc) has a recommended procedure for repairing RADIAL tires:
    Dismount the tire
    Clean out the hole and frayed belt with an apporpriately sized high speed rotary file. Nice round hole with no frayed wire ends.
    Lightly buff or clean the liner with rubber buff solution.
    Apply cement to the buff area and into the hole
    Allow the cement to tack off. VERY important
    Use a pull through plug and patch combination that is slightly oversize for the hole.
    Pull through the plug, s***ch down the liner patch to remove any trapped air.
    Pull slightly on the plug from the outside and trim off flush.
    The plug prevents moisture from entering and rusting the belt package, and the patch seals the air cavity and reinforces the belt package and body plies.
    If it's good for 200K miles in truck tire, it's good for your car.
    Find another tire dealer.
  28. slayer
    slayer
    I forgot about plug patches. These were too high tech for the place i worked. They do seem like the best of both worlds.
  29. LowKat
    LowKat
    bigger screw
  30. LANCE-SPEED
    LANCE-SPEED
    ********SPAM ALERT*********SPAM ALERT******SPAM ALERT***
    We sell this kit for off roaders. retail $39.99, special HAMB price $34.99
    give me a call
    800-337-9005 ext 5410, Lance
    <LI nodeIndex="1">Tire gauge<LI nodeIndex="2">Insertion needle<LI nodeIndex="3">Lubricant<LI nodeIndex="4">Valve core tool<LI nodeIndex="5">Four valve stems<LI nodeIndex="6">Four valve caps<LI nodeIndex="7">Reamer tool<LI nodeIndex="8">30 self vulcanizing repair cords<LI nodeIndex="9">Two allen keys<LI nodeIndex="10">Orange molded case
