What's doin' inside your garage tonight?
Discussion in 'The Hokey Ass Message Board' started by 2many projects, Oct 18, 2008.
  1. Weasel
    Weasel
    Silicone brake fluid DOT 5 should only be used on vehicles whose seals are compatible. Rubber seals get eroded and without warning - pedal to the floor and you loose your brakes - it happened to me and I nearly took out the NSRA Safety Tent. Heed the warning on the can, from the brake manufacturers and from all major vehicle manufacturers. There is no good reason to use it on street driven vehicles.
  2. Kirk Hanning
    Kirk Hanning
    Flathead Pete, Jdubbya and I unloaded a Bridgeport that I picked up today. Sunday will be the day to wire up the 3 phase rotory converter so I can start it up and listen to it hum. I also broke down a 28-29' Model A cowl for the gas tank and firewall that I'll be using on the next project.
  3. Im finnishing the center of the ceiling with the wiring and insulation so a buddy can come to do the LAST of the sheetrock in my shop.New lights and a/c & heat (if needed)...then its back on the piewagon...hopefully my new dropped axle will be here this week....
  4. TV
    TV
    Kev(Hotrodvon) and I (TV) put the race engine and trans back in our 27 modified and worked all day hooking up all the little things,getting ready to race it next week end at El Murage. We had thrown the flywheel at Bonneville this year and had to weld the flange and all of that stuff. We didn't do the welding or macineing or the short block. But we still did alot of the work. The car itself is showing some wear from El Marage runs and our trip to Bonneville. After next week end we will take it down for some body repair and paint clean up, so as to be ready for next years start. I'm sure most of you have sean it, so I won't post any pictures. But I will tell you racing sure cuts into your hotrod time and fun, my 32-5 wind. with it's Riley has been waiting for it's turn as well as a trans for Kev's 32 roadster for most of this season---But we are having funnnnn.--TV
  5. Flatman
    Flatman
    I just got finished cleaning the filler dust from the kero heater in preparation for the cold. Gotta get the place cleaned and find that ambition I've been missing...:D
    Flatman
  6. Well I pulled my 276 Hemi apart, at least the heads, intake, and valley pan. It has quite a bit of sludge as it only had a blow tube. Its got .008 taper on the bores but......everything else looked good. Never bothered cleaning out my garage first as I'm impatient .!!! So now I've got a hell of a mess!!!!!
  7. AstroZombie
    AstroZombie
    from Marina, CA
    i'm peaking the hood on the buick, and maybe the trunk too..... pics later after the good looking girls leave my house :) hahaha! as i said pics to follow!
  8. turdmagnet
    turdmagnet
    Started replacing the leaf springs and rear axle - damn those original rivits are a ****** to get out - certainly built them to last. Got the axle out, one spring, and one spring mount - heading out to get the rest today (i hope !!!)
  9. Kerry67
    Kerry67
    Vending at the Good-Guys swap next weekend so I have stuff all over the garage getting it ready.
  10. CRH
    CRH
    from Utah
    Making patch panels for the '27 T roadster's doors, and making door panels even though the car is long from ready for 'em. Woohoo!
  11. junkyardgenius
    junkyardgenius
    from Kernow
    send beer
  12. Just finished up putting in a remote start in our Grand Cherokee for my wife.Gets cold up here.....
  13. Welding, welding, welding.........
  14. swade41
    swade41
    from Buffalo,NY
    I'm tearing out an 8X8 storage room out of my garage so I can have a bit more room, almost done. The problem is that the stuff that was stored in there has to find a new home.
  15. 29nash
    29nash
    from colorado
    ..........back up on jack-stands to install new 650x20s on the rear and tweak the suspension so they'll fit good in the rear fenders. Those in the pic are 500s.
  16. roosters hot rods
    roosters hot rods
    i think i'm going to sweep it out then sit and look at my hotrod drinking a beer...lol
  17. Rocky
    Rocky
    Classified Editor
    went to U-pull-it to score a pair of proper dist cap clips to attach my 42-44 crab cap to my old 59-AB style distributor. I searched under the hoods for distributor clips but everything had screw-on caps...damn! I ended up finding my clips on late model air cleaners....who knew? I grabbed about 6 different styles and also found some from an old '79 Porsche 924 distributor lying in the back seat. Ended up using them.
    The **** we use to get our stuff going.....the porsche also surendered up a nice quartz VDO 2" clock that matches my stewart warner gauges....cost 2 bucks and keeps perfect time.
  18. breeder
    breeder
    lookin out in my yard, drinkin a beer, wondering why i havent robbed a bank to get my shop built!
  19. 6t5frlane
    6t5frlane
    from New York
    Raked and got the leaves in order. No Garage tonight. A PBR long neck and Football
  20. dentisaurus
    dentisaurus
    from Boston
    spent today installing new lights and power in the garage. Now I can see what I'm doing past 3 in the afternoon!
  21. Von Dago
    Von Dago
    from New Jersey
    Picking away at the '33 Woodie.
    I need a gl*** of wine.
  22. iamspencer
    iamspencer
    dont have a garage, will be out side welding by fire light....
  23. sjrodder
    sjrodder
    from vermont
    finished putting together a 48 ford axle for my 29 coupe
  24. Von Rigg Fink
    Von Rigg Fink
    from Garage
    freezing my *** off:mad:
    need to get this roof leak fixed and get that insulation up before it really gets cold:(
  25. Jarred Hodges
    Jarred Hodges
    I sold one of my mavericks that I was using for parts, helped my uncle clean up his farm, and I bought a 75 Ford elite that has a good 351w for $60 from him. I am slowly collecting parts for a T bucket project I want to build
  26. n1gzd
    n1gzd
    from Acton, MA
    Stripped and painted my 36 Plymouth engine this past weekend, after spending a couple of weekends struggling with a front motor mount replacement (not quite stock). I will post a pic of how the engine came out when it is done:
  27. Hank37
    Hank37
    I,am working on putting a 62 Falcon body on my 90 dirt modified stock car. Going to run with the Vintage guys next spring.
  28. rustingbucket
    rustingbucket
    If by "garage", you mean tent, I be cutting out the transmission brace in my coupe, and prepping the frame for the new(next) one. Man, I wish the plasma cutter fairy would leave one under my pillow!
  29. ronniemckinney
    ronniemckinney
    from Alabama
    A buddy and I spent the day turning my 53 F100 into a 53 Ranger...
  30. lostforawhile
    lostforawhile
    finally figured out whre I want to mount the radio,custom box under the p***enger seat, figured out where to run the extra fuse box, going to run a bunch more wiring, and hooking the blower to the heater box. that silicone aircraft hose is a ****** to make tight bends in.
