Whats everybody,s choice in cut off wheels and there source for them
Discussion in 'The Hokey Ass Message Board' started by jimcaf, May 2, 2011.
  1. jimcaf
    jimcaf
    from san diego
    I did a search and didnt come up with anything on it..I plan fine fitting and tig welding or gas welding "**** welding"all my work.So this seems to be the best avenue for slicing sheet metal on a chop and that sort of thing. I really like the green 3m little wheels but the price! I got some cheap off ebay and they cut but man they wear out super fast and there is dust all over...what do you guys like and where you buying them from,,,thanks jim
  2. Ole don
    Ole don
    I have bought them 10 for two bucks at a swap meet and they are gone in no time. Go to the welding store and buy the good stuff, pay the price and forget about it. Its the cost of doing business.
  3. Jim Stabe
    Jim Stabe
    The later HF ones I have bought have been holding up fairly well. I bought some name brand a couple months ago and they were not noticably different. Probably which Chinese sweat shop they bought from this month.
  4. zman
    zman
    from Garner, NC
  5. Roger O'Dell
    Roger O'Dell
    3m green corp 1/32, cost more, but last longer. Ebay. Roger
  6. aerocolor
    aerocolor
    from dayton
    We only use 3M as they don`t come apart and last longer than anything else we`ve tried. I do believe I`ve bought those from every manufacturer that makes `em.
    3M discs aren`t cheap. $20 for 5-pak.
  7. ford1932
    ford1932
    from Canada
    Find some Falcon abrasive's cutoffs (www.falconabrasive.com). Way cheaper tham 3m and Walter, USA made, and last just as long. Their premium cutoffs are made with 3m cubitron and are pricey but work real well on stainless. Check their website for a dealer ....
  8. Retrorod
    Retrorod
    I use 3M or Norton Abrasives wheels. Sometimes the ones you get at HF are ok, mostly not...they don't last.
  9. dodored
    dodored
    from Concord NC
    I was just shopping for some more wheels, so funny you bring this topic up. I usually go to the local welding supply store and buy the cheapest 3 inch wheels they have. I have paid as little as 95 cents each and as much as $1.75 a piece. You can find a good deal on Ebay from time to time as well. What is everyone paying each?
  10. ironpile
    ironpile
    I use 4inch x1/16 inch cutoff wheels in my air angle grinder to cut most of the weld down just proud of the surface,then I use the roloc disc.Just purchased 25 3inch ***orted "s" type discs on ebay,no auction just buy it now,have proper backup pad coming. I`ll post how I think they work. Good luck
  11. slammed
    slammed
    Would it help to split up a box/case with a couple of guy's? I need to stock up on all this related supplies.
  12. wildearp
    wildearp
    from tucson, az
    I get the 20 pack at HF with a 25% off coupon. I have been using them for over 10 years with great results. If your air tool doesn't spin them fast, they will wear quickly. This is true for any of the abrasive wheels.
    I use a 90 degree pneumatic tool. Not all of these spin fast enough.
  13. olddrags
    olddrags
    from ky
    Ive had real good luck with the 4" from the local Ace Hardware store, pack of 5 for less than ten bucks, seen to last a little longer than 3M.
  14. goose-em
    goose-em
    from Louisiana
    I use Flexovit and pay $27 for a box of 25. Best deal around.
  15. Metabos from Fastenal.
  16. hammer bowling
    hammer bowling
    Sait brand "borrow" them from work.
  17. zman
    zman
    from Garner, NC
    If you look at the link I posted. Metabo's for $.064 ea. that's less.
  18. F-6Garagerat
    F-6Garagerat
    Metabos here too. I get a stack at the welding shop whenever I get oxy/acetylene refills.
  19. loveoftiki
    loveoftiki
    from Livonia,Mi
    3M you get what you pay for. When you look at how much longer they last compared to the Chinese junk it cost you more to use the cheap stuff, also look at the safety issues. A cut off wheel flying apart and paieces flying near you face is never fun. PLEASE WEAR A SHIELD AND SAFETY GL***ES!!!!!
  20. Greezeball
    Greezeball
    We quit using the Sait discs the centres pull out of them (may have been a bad batch) we use Walter or 3m. Everything we work on is stainless mostly 316. Also if a cut takes 4 sait discs I can do 2 with one Walter.
  21. jimcaf
    jimcaf
    from san diego
    Thanks for all the responses.I have found in it does seem to be you get what you pay for.3M has always made the best stuff in the body shop business.I been hearing good about Metabos, Im going to pick some up this week give them a shot... jim
  22. bp1971
    bp1971
    from Fresno, CA
    I've been using HF on my straight die grinder with great results.
  23. lippy
    lippy
    from Ks
    Me too, they are thin and slice right thru sheet steel. Wear good and cheap. CP's made in russia. If the blade is too thick it tries to burn on top instead of cutting. And yes, spin the **** out of them. Lippy
  24. cowboy1
    cowboy1
    from Austin TX
    3m . HF IF I'm in a bind on a Sunday and my supply house is closed. They don't last as long. I've even used the DeWalt brand.
  25. olds vroom
    olds vroom
    I use walter zip wheels they seem to last 3 times longer
  26. Bryan G
    Bryan G
    from Delmarva
  27. _ogre
    _ogre
    from Motown
    never had any luck with the little wheels on a die grinder
    i use 5'' or 6'' wheels in a 4'' angle grinder.
    i have a couple of grinders so i don't have to change wheels all the time
    i buy my cutoff wheels at the local industrial supply
    they usually have sait, HD also carries sait but they cost $1 there
  28. jimcaf
    jimcaf
    from san diego
  29. FoMoCoPower
    FoMoCoPower
    3m green corps FTW,you can find them cheap on ebay
