What's everyone building? Can we sum it up?
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Dec 28, 2007.
  1. 8769
    8769
    from kennesaw
  2. Anderson
    Anderson
    Excellent idea.
    Here's mine...
    Mock-up
    http://www.jalopyjournal.com/forum/showthread.php?t=153621
    Starting the frame
    http://www.jalopyjournal.com/forum/showthread.php?t=196726
    More frame work
    http://www.jalopyjournal.com/forum/showthread.php?t=201041
    More frame stuff and the windshield
    http://www.jalopyjournal.com/forum/showthread.php?t=215157
    Rolling it outside, installing X-member, rear shocks
    http://www.jalopyjournal.com/forum/showthread.php?t=219852
    Motor installed, changing to ladder bars, steering box mount
    http://www.jalopyjournal.com/forum/showthread.php?t=224565
    More windshield stuff
    http://www.jalopyjournal.com/forum/showthread.php?t=231070
    Hopefully there will be another update after this weekend.
    Here's my photo album with everything in it.
    http://www.thefidgiter.com/modified/
  3. j ripper
    j ripper
    from napa ca.
    this is one i am currently working on.. i for some reason never take pictures of anything i build.
  4. jj mack
    jj mack
    You are right!!! Ive missed most of these!!
  5. NealinCA
    NealinCA
    I've been back on my 32 rpu project pretty consistent this year.
    It started back in 2004, but then got put aside for a couple of years while life got in the way.
    Firewall repair
    http://www.jalopyjournal.com/forum/showthread.php?t=11076
    Pedals and M/C mount
    http://www.jalopyjournal.com/forum/showthread.php?t=17597
    Rear shocks
    http://www.jalopyjournal.com/forum/showthread.php?t=21361
    Photoshop coming to life
    http://www.jalopyjournal.com/forum/showthread.php?t=24581
    Ch***is build
    http://www.jalopyjournal.com/forum/showthread.php?t=25304
    Now jump forward 2-1/2 years...
    E-brake and floor board
    http://www.jalopyjournal.com/forum/showthread.php?t=162909
    Brakes and spindles
    http://www.jalopyjournal.com/forum/showthread.php?t=215720
    Coil conversion and Engine Pics
    http://www.jalopyjournal.com/forum/showthread.php?t=226067
    And a somewhat recent pic of the ch***is.
    I am working on the cab and bed now...which, at the rate I work, will consume the better part of 2008.
    Neal
  6. mazdaslam
    mazdaslam
  7. Elmo Rodge
    Elmo Rodge
    Flathead powered P-38 Belly Tank for Bonneville. Wayno
  8. flathead48
    flathead48
    We're building a 30' Model A coupe. 4" chop, 4" channel, z'd 5". Will be running a 401 Nailhead mated to a 5spd, and a 9". Hope to have it road worthy or very close in time for summer.
  9. AHotRod
    AHotRod
    Great idea Scooter !
    My A-Sedan project has taken much longer than I wanted it to, but I'm within a couple of weeks of being finished and on the road.
    I made a BIG change in the car from beater-to-finished, which added another year to the job.
    Here are links to what has been posted:
    1. http://www.jalopyjournal.com/forum/showthread.php?t=79649
    2. http://www.jalopyjournal.com/forum/showthread.php?t=89250&showall=1
    3. http://www.jalopyjournal.com/forum/showthread.php?t=89554&showall=1
    4. http://www.jalopyjournal.com/forum/showthread.php?t=97260&showall=1
    5. http://www.jalopyjournal.com/forum/showthread.php?t=138018&showall=1
      24.6 KB
  10. fitzee
    fitzee
  11. Scott B
    Scott B
    from Colorado?
    I am still putzing away on this...
  12. Eddiesixem
    Eddiesixem
  13. Rocky
    Rocky
    Classified Editor
    34 ford 5 window....
  14. kwiksilver
    kwiksilver
  15. Tony
    Tony
    Currently rebuilding a 52 chevy truck i bought this past summer....
    Once that's done, it's gas on with the 32 5 window i've had for too long without me doing anything to it...
  16. evil1
    evil1
  17. Kirk Hanning
    Kirk Hanning
    Here is my 34' pickup that I started 6 months ago, hopefully will be driving early spring to mid summer 08'. 57' 365 Caddy with a Edelbrock 4 duece intake topped with 94's backed by a M-21 Muncie 4 spd. Rearend is the motor's original partner. The cab is chopped 4" channeled 6" with a Model A box that I shortened 6". The frame is built out of 2 by 3 tubing 3/16 wall with 1/4 elliptics at each corner. 17" Kelsey Hayes with 5.50-17 up font and 7.50-17 out back...damn they ARE tall. I about sh*t when they arrived from Coker, but hey why not? Just got the tires in a month ago and just finishing the floorpans as we speak.
  18. Badfast
    Badfast
  19. taylormade
    taylormade
    50 Dodge Wayfarer Roadster. Getting a Red Ram Hemi, four wheel disks, new ****** and rearend. Gonna be red with a red leather interior. Stock frame and front end with repositioned shocks and maybe rack and pinion depending on how the hemi slides in.
    Body looks good but isn't. Need to reskin bottom of doors and replace metal between door and rear fenders. Trunk and rear floors are solid, but front floors are gone with a really ****py repair job covered with bedliner. The good news - I have four NOS fenders.
    All the body mounts on the car are toast - just rotted away. The body is basically sitting on what's left of the floor. The boxed inner rockers are also just about gone. I'll be doing a lot of metal work this winter. Lucky for me I found a convertible parts car with solid mounts and a better frame, so part of the problem is solved.
    I think I'm looking a two years if the money holds out..
  20. Sam F.
    Sam F.
  21. sko_ford
    sko_ford
  22. I am finally workin on my '34 Ford pickup, I got it mocked up on 4 wheels for the first time a couple of months ago. Here are the details
    • '34 cab 4 inch chop, flat firewall, Homemade bed, fenderless
    • Stock '34 frame boxed, 4" dropped axle, '40 split front wishbone, '46 Ford spindles and frt. brakes, parallel rear leaf springs, and a Bronco 9 inch rearend.
    • 1955 Cadillac 331, 200r4 trans.
    • 16 inch '40 Ford front wheels with 6.00
    • 16 inch Ford F1 truck rear's with 7.50's
    That is as far as I am right now, here is the frame on its wheels for the first time.
    CBB
  23. '51 Chevy, full kustom,,,finished the suspension this summer...
    http://www.jalopyjournal.com/forum/showthread.php?t=202220
    I've been wrapped up with other projects, but now I'm turning my focus back to this car...hoping to finish the body mods soon 'cause there are a couple other cars we've got to get on the road.
    Bryan
  24. Just Gary
    Just Gary
  25. im working on a 37 chevy 1/2 ton pickup unfinished pile O **** same ****ty story started with a cab and a wrecked S10 presently it has a 454BBC 400 trans , 9inch ford rear .. i am planning on going full fendered to cover the hiedious S10 frame ..
  26. Blue70
    Blue70
    I'm building a 40s Dodge truck...
    But it's not traditional, so from what I've seen, most here will not like it... That's OK though, cause it's mine ;)
    If I had to buy parts I would have done it differently, but I'm doing this for about free :D
    http://www.jalopyjournal.com/forum/showthread.php?t=230445
  27. andysdeuce
    andysdeuce
    How 'bout a '29 "A" roadster on Unboxed "A" frame...301 s.b.c...m21 muncie...9in. ford rear. '49 mercury dash...'34 commercial grill...'48 packard tailights...f100 steering w/'57 ford wheel..blc682c's on f100 shock mount stands...'40 ford front bones and '34 rear bones. Doing body work and paint now. Gonna be '40 ford maroon with creme wheeels and scallops...if I don't change my mind. If anyone is interested in pics I'll try to post a few. If not you will see it on the road this summer if I can get my big **** in gear!!!:D:D
  28. tommy
    tommy
    A traditional weekend warrior from the early 60s. A cheap sedan with a big motor for cruising the Mighty Mo. Roll up windows with a heater. It don't get no better that that!:D
  29. HOT40ROD
    HOT40ROD
    from Easton, Pa
    Trying to finish the Model T between all of the bikes and parts I am making for everyone else.
