What's everyone building? Can we sum it up?
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Dec 28, 2007.
  1. Toast
    Toast
    from Jenks, OK
    Building this 35 International also a full custom 62 Buick (that I tried to Burn up) and a Mild custom 63 T-Bird
  2. 27T
    27T
  3. Well this is what I was building, its gone on its merry way now for my next project.
    Its gone and I am startin on an A-40 G***er, will post some pics when I get em, mainly collecting parts right now.
    Doc.
  4. Flop
    Flop
  5. thats lookin great doc , i see what looks like a tri5 dash in your future!:D very cool
  6. Dog_Patch
    Dog_Patch
    Here is my 32 Ford Truck cab thing. It started out in the girl friend's garage so it needed to be short to fit the garage. Hammeredabone used the Fidgeter's model as a guide for the frame build. We hand built the rear frame rails. If all goes well, the engine will be running today or tomorrow and then the cab needs mounted and chopped, floor done and wires and it should be on the road by Feb - I hope ;).
  7. shock
    shock
  8. Yeah, 57 dash. Its on another car now. This one was to have a DuVall screen that sat very nice on there. The guy that has it put a standard screen on it and it has ugly gaps between the humps and fits terribly!
    I miss the car real bad, but this was my second 28/9 A RPU and I always wanted a G***er so it had to go.:(
    But G***er makes me go:D
    Doc.
  9. Paul
    Paul
    Editor
    inspiring thread,
    what am I building?
    looking around the shop I see it aint much..:rolleyes:
    should be working on the Coupe
    started two? years ago... I ****:(
    but you can see behind it the new sheetrock and paint I've been putting up:)
    and I did pick up this 394 Olds wonder off craigslist for $50.00
    a week or so ago..
    made an oil primer for it out of a spare distributor
    and put a $10.00 swapmeet battery box in the T...
    like I said, it aint much.:rolleyes:
  10. HotRodChassis
    HotRodChassis
    Alliance Vendor
  11. chaddilac
    chaddilac
  12. 40StudeDude
    40StudeDude
    Sled -- 1955 Caddy Coop DeVille...'78 Trans Am sub-frame, '70 Caddy 500"/Turbo 400...close to being driveable...wiring finished, installed '56 Caddy dash, painting dash, trim and tilt column, using stock steering wheel...body work is next...
    R-
  13. HotRodChassis
    HotRodChassis
    Alliance Vendor
    Chaddilac, those tail lights are awesome! What are they from?
  14. K13
    K13
    I'm building a 37 Chev pick up.
  15. K13
    K13
    Here is the other end.
  16. SUHRsc
    SUHRsc
  17. mosimpson
    mosimpson
  18. Hemi325
    Hemi325
    from Boerne, TX
    My projects are a Victress-Hemi and a 34 roadster.
  19. krowbar
    krowbar
    from michigan
    I am pounding iron on a 39 ford coupe, 53 flathead, f-1 brakes, original optional shock mounts. Bought the car in Illinois from an old man, and i dont know if he or someone else had tried to rod it. They shaved the trunk lid handle, gas cap door and the tail lights. Pontiac tail lights were installed on the body between the fenders and trunk lid. I also got a Canadian flathead with trans, two narrow wide five rims. Names such as "Rat", "CW", Huck, etc.. are carved into the horn ring. The car is 90%, but needs alot of work. As of now i have a rolling frame with everything blasted, primed , and painted. I will try to post some pic if i can figure out how..........................
  20. krowbar
    krowbar
    from michigan
    I'd like to see some pics of that
  21. SanDiegoJoe
    SanDiegoJoe
    This was a damn good idea.
    - Joe
  22. charleyw
    charleyw
    My longterm (unintentional) project. Big block F-1, 3" chop, Volare front suspension, 9" rear. I swear I'll finish it in '08, no.. really!
  23. scootermcrad
    scootermcrad
    I'm stoked this thread took off like it did! It's been a HELL of a read! There are some super awesome builds going on here! Keep it goin! I noticed a few people that ALWAYS have some *****in' rides in the works haven't post yet. Hope they post. I'm pretty sure they know who they are! (nudge, nudge)
  24. movin/on
    movin/on
    After I finish a 56 F100 with a 390 &C6 (to sell)
    I'm undertaking a major chop job. My stock 48 Lincoln Continental will get a 351W C-6 & Narrow 9" rear. & a 4"chop. Otherwise stock inside and fenders left for later mods.
    I may be asking for advise for all of the cuts & sections to add. An English wheel will be used for the modified panels.
    Read the tech on how to cut & weld stainless trim. Great help on this end
  25. 28 chevy
    28 chevy
    from NE Pa
    28 chevy mild rod. 350 sb. 83 buick rear. stock front axel with disc brake kit. vega box. chrome smoothies.
    drivetrain is done.working on the wood!!
    Jim
  26. yekoms
    yekoms
    '34 5 winda...
  27. Autoslim
    Autoslim
    from texas
    I've got a 64 Comet post (former radio delete - 6 holer - 3onthetree) that is under going a transformation into a altered wheelbase straight axle match racer.
    For a base I got a 57 Fairlane 9 inch, Econoline front axle, a 1969 351W and a top loader 4 speed (I know, I know...I wish I had an FE).
    I cut the axle and drag link 5.5 and welded back. Rebuilt the king pins and had the springs rearched. I switched the shackles to the front. I'm working on fabbing the cross steer arm. Front axle is up 3 inches and ultimately the rear will be moved up 12 inches (or so).
    The front has Torq thrusts skinnys and the rear are vintage Kelsey Hayes chrome reverse.
  28. Dan Hay
    Dan Hay
    Building a 1/8 32 ford. Don't have the room or the $ to work on the 38 this year.
  29. TERPU
    TERPU
    I'm just about finished with this. Put the final polish on it yesterday and the upholsterer is coming Monday to look at it.
  30. v8minor
    v8minor
    Long term project is my 50 chevy ,was a rusty 4door pile , now 4 inch chop full kustom grill ,2 door ,need to finish the window swap and get the engine swaped for a later 235.
