Whats everyone using to clean old parts with?
Discussion in 'The Hokey Ass Message Board' started by GomezGarage, Oct 6, 2004.
  1. GomezGarage
    GomezGarage
    Chemical Tanks? What chemicals are cheap and work best? Has anyone used the new sound wave tank? How about those nut and bolt tumblers from Eastwood? Currently Ive got a chemical parts washer with some not so effective degreaser hence the post topic. I work in the pool industry and was thinkin about using hydorchloric acid but that stuff is pretty caustic. Any tried and true reciepies out there?
    wood remover likes this.
  2. DrJ
    DrJ
    Simple Green for most stuff, mineral spirits for internal engine parts etc.
    jeffd1988 likes this.
  3. IntrstlarOvrdrve
    IntrstlarOvrdrve
    Oven degreaser, I've used that a couple of timse on some relaly tough stuff with good sucess.
  4. Crease
    Crease
    I like denatured alcahol. Stay away from the stout carb cleaner stuff, it'll jack you up.
  5. porkshop
    porkshop
    from Clovis Ca
    I use a five gallon bucket of casteroil super clean and a dip basket. let em sock overnight and it removes all the grime paint etc. dont use it on alluminum it turns it black then turns to white powder. [​IMG]
  6. I use an Eastwood ********y tumbler for small parts. Works well. Stuff needs to be degreased though
    Large greasy **** gets a dip in our Safety clean washer.
    I have a carb can for carbs. NAPA brand, it ****s, no basket
    Carb cleaners and Laquer thinner is my pal good ****.
    henryj1951 likes this.
  7. atch
    atch
    gomez,
    there have been several posts on this topic over the years. if you do a search you should find some of them. there are LOTS of suggestions. good luck, and let us know what works best for you.
  8. briggs&strattonChev
    briggs&strattonChev
    if you want a good degreaser and to remove old paint, id use easy off oven cleaner. Spray it on the part and let it sit, then either rinse or carefully brush (so you dont get anything in your eyes). I degreased a whole engine in a truck with a few cans of easy off, worked very well with just a water hose to rinse (no pressure).
  9. Gracie
    Gracie
    My exboyfriend's toothbrush.... I'll send it back to him one day.
  10. roaddevil
    roaddevil
    Flash 140 solvent this **** will eat the paint off and your finger tips.
    Super clean and a heated power washer..
    Or let the dog chew the ****z right off, that what happens when your cross a dane with a lab
  11. RagDoll
    RagDoll
    I've gotten some good results with the trusty kitchen dishwasher, easy off oven cleaner and at times Simple green. As long as the parts fit in the dishwasher, and I got as much crud off as I could it worked fine. Some parts were so cruddy, it took a couple rounds of scrub by hand and dishwasher. Hope this helps! OH yeah...run the dishwasher empty a couple times with dishwashing cleanser, wiping large particles off by hand if necessary before putting your dishes back in there!
  12. Blownolds
    Blownolds
    from So Cal
    Plastic lenses, simple green and water.
    Greasy parts, gasoline or Berryman B-12. Be prepared to dispose of at a haz-mat place.
    Rusty stuff, wire wheel.
    Overspray, lacquer thinner, as long as you're not working with a plastic or painted surface. Not sure about anodized. But lacquer thinner is awesome on stainless trim.
    Sand cast aluminum such as intakes, real gl*** beads. But I usually have sandblasted and then paint with silver paint that matches as-cast. Oh, and you need to de-grease at least all the wet stuff before blasting or your media will get messed up. One reason I just have sand blasted, but I have to degrease for him too. Oh, and only do this method on rough-cast surfaces too-- altough gl*** beading will leave a cool satin texture to a polished surface.
    Undercoating, aircraft stripper OR torch and putty knife. Finish cleaning with wire wheel and/or lacquer thinner.
    Painted panels, aircraft stripper. (nasty, nasty stuff though-- don't breath or get on skin).
  13. adzslick
    adzslick
    I have an industrial chemical called BG, mum's company uses it in fire restorations of houses and **** ..... needless to say it is awesome.
    for rusty ive been using vinegar 4 litres and 1 small citric acid container mixed together, strippin rust off brake drums and **** like that like nothing else and does it overnight
    cheers
    adz
  14. polisher
    polisher
    Alliance Vendor
    For small parts we use simple green or pink stuff to remove
    the grime and we remove rust with an eletrolytic tank.
    Ultrasonic cleaners are oK but big ones are expensive and not good for br***, bronze, zinc or aluminumum.
    Simple green and pink stuff work much better if heated to around 120 to 140 degrees F.
  15. lothiandon1940
    lothiandon1940
    ..........................You do realize that this thread is over 13 years old!:eek:
    pat59, scrap metal 48 and jeffd1988 like this.
  16. jeffd1988
    jeffd1988
    Simple green to clean up any dirty grimy parts with oil or grease on it. And to get rust off metal or watever to make it look like new without all the b.s. Evaporust that stuff works miracles tbh. And is environment friendly.
    Sent from my Z981 using The H.A.M.B. mobile app
    lothiandon1940 likes this.
  17. 2935ford
    2935ford
    Greasy stuff.....varsol
  18. bobss396
    bobss396
    Zombie posts always crack me up...
    pat59 and lothiandon1940 like this.
  19. rusty rocket
    rusty rocket
    This thread is 13 years old but we can still add to it with some good info.
  20. scotts52
    scotts52
    I've used diesel and a stiff brush to loosen caked on grease. Another thing I've used is Drano (gotta use the crystals as the liquid isn't as effective)
    To remove rust I've soaked things in phosphoric acid. I've been told not to use it on suspension parts though because it could cause hydrogen embrittlement.
  21. Truck64
    Truck64
    from Ioway
    What do solvent tanks at the shop or on the floor use? Some kind of petroleum or deoderized kerosene right? Can't really get much better n that. Anything not too stinky or flammable is right in there.
  22. HOTRODPRIMER
    HOTRODPRIMER
    We used Varsol in our tank. HRP
  23. wbrw32
    wbrw32
    Most "hot tanks" in older days used "Oakite' in the water....
  24. Truck64
    Truck64
    from Ioway
    Right. So a handy equivalent in just about every hoodlum's garage would be charcoal grill lighter fluid. Aka paint thinner or sometimes called Stoddard solvent.
  25. Oldmics
    Oldmics
    So where does one purchase REAL -Varsol these days ? Not that Varsol subs***ution ****.
    Oldmics
    LTM75110 likes this.
  26. Truck64
    Truck64
    from Ioway
    Easy. If the label says "New and Improved!" that ain't the stuff.
    Oldmics likes this.
  27. bangngears
    bangngears
    from ofallon mo
    Just use solvent from the local hardware store. Does ok, but when i was in the service we got some stuff from the flight line we put in a 50 caliber ammo box. We would put a greasy intake in it and 30 minutes later it looked brand new, down to bare metal. Dont know what it was but would like to find out. Any one on a flight line somewhere that can chime in?
  28. Truck64
    Truck64
    from Ioway
    When? They sicked the EPA after the .mil while I was in, or started to, by the 90s. "How long has that oil can been sitting there?" Yeesh.
    1,1,1, Trichlorethane aka "Trike" was used a lot. Since been defanged I'm sure. MEK would be another good candidate.
  29. Engine man
    Engine man
    from Wisconsin
    Careful with the Drano. If you buy a lot, the police will suspect you're making meth.
    lothiandon1940 and jeffd1988 like this.
  30. dan31
    dan31
    Fore shot from the still,can't drink it but it makes great parts cleaner.
