Technical What's it worth? 303 Olds Manual Bellhousing
Discussion in 'The Hokey Ass Message Board' started by chaddilac, Apr 23, 2014.
  1. chaddilac
    chaddilac
    Got this little project and want to keep the motor and peddle the rest to a rat rodder... hopping the manual bellhousing will pay for another automatic trans... can you guys tell me what it's worth... Someone adapted a jeep or something trans to it.
    Bellhousing, clutch, and flywheel and starter are all together.
  2. Beachcomber
    Beachcomber
    from Phoenix,AZ
    olds to gm trans? $300 or so. Wilcap wants $475
  3. chaddilac
    chaddilac
    Yea I'm not sure what trans that is... someone identified it as a 70s jeep I think.
  4. Paul
    Paul
    Editor
    from what I see the engine and bellhousing are all I would keep
    is the bellhousing one meant for a secondary plate adapter?
    I did have one at one time, it had a protruding lip at the input opening..
    whatever.. Beachcomber is about right at $300
    of course me being an absolute cheapskate
    I would never pay that much for a used one, if I was looking.
    if it were mine I'd throw it on the pile till I needed it.
  5. chaddilac
    chaddilac
    What trans would bolt up to that Paul? I have access to a muncie.
  6. ROADSTER1927
    ROADSTER1927
    I do not think you can tell what will fit without taking the trans off. Gary
  7. 302GMC
    302GMC
    from Idaho
    Most of the modified examples are hogged out for different bearing retainers.
  8. Depending on the Jeep it could take Ford toploader, GM pattern, or who knows what. I'd check it out and go from there. Jeeps seemed to use whatever trans they could buy cheapest in a given year.
  9. chaddilac
    chaddilac
    Thanks fellas!! Thank you RustyNY!
  10. Beau
    Beau
    If it were a 215, it would be real good money.
    If it's a Jeep trans it might be a t-90 (I think???) which is the same as a T-5 GM pattern. Could be good money.
  11. chaddilac
    chaddilac
    Yep I'll get some more pics of the trans and y'all can figure out what I got then!!! :D
    Thanks for the help!
  12. Beau
    Beau
    That front wishbone is pretty funny.
  13. chaddilac
    chaddilac
    Ha!! My thoughts exactly!!
  14. chaddilac
    chaddilac
    See if these pics help?
  15. 302GMC
    302GMC
    from Idaho
    Not a factory Olds part ... McBar sold a bunch of this early stuff. Heathen will know ...
  16. Paul
    Paul
    Editor
    looks just like my old one,
    made the steel plate adapter myself
    to put a Chevy transmission behind a 394
    tried to find a picture
    but back then it was all Kodak Instamatic
    and I didn't stop to take a lot of pictures ;)
  17. The adapter is a TransDapt. As mentioned, dis-assembly should tell you what it fit originally. There's also part number on it....JC-something....if it's JC-25, it's Olds to Chevy pattern.
    I've seen these for a bunch of different transmissions. Some more info here...
    http://www.jalopyjournal.com/forum/showthread.php?t=140319
  18. chaddilac
    chaddilac
    Get ta scanning Paul!! :D
    Thanks Rusk! I'm gonna pull it and see what I got!! Thanks for the help!
