67cc combustion chamber keith black 120 .308 block hasnt been decked stock replacment head gasket for 350 sbc Thank you. If it makes a difference, Im trying to figure out the camshaft to run. Chevy truck 373 gears 3 speed on the column manual trans 600cfm 4bbl carb ramhorns and performer rpm intake manifold thanks you Im torn between a 262 or a 268 camshaft
I would go with an R.V. style cam shaft your not using an exaust system that will allow the engine to breath at higher RPM's you want grunt and torque to get a full size truck moving
Your total cc's will be between 90-95 depending on how far down the piston is. You should be around 9.25-9.50 c.r.
