What's Really Happening On A Lathe???
Discussion in 'The Hokey Ass Message Board' started by ClayMart, Jun 11, 2012.
  1. ClayMart
    ClayMart
    I don't think you really know what's happening when you're watching metal being turned on a lathe. :confused:
    I know I didn't until just a short time ago. :eek:
    http://www.wimp.com/cuttingsteel/
  2. Interesting but also sleep inducing after a minute or two.
  3. 32ford5
    32ford5
    from Australia
    That was cool. There realy is no "cutting" is there? Only controlled destruction and it was also interesting to see how the actual tip of the tool bit did very little cutting at all. It was mostly done by a leading bit of captured original material.
  4. jw johnston
    jw johnston
    i dont remember it creating that orcestra sound when i was running a lathe. funny my cutting speeds must have been off. . . . .
  5. WhiteZombie
    WhiteZombie
    from Denton TX
    That's pretty cool...it is a bit hypnotizing.
  6. burl
    burl
    from Minnesota
    forgot the chip breaker
  7. tb33anda3rd
    tb33anda3rd
    i understand know why it is good to have sharp bits.
  8. bobss396
    bobss396
    Some of that looked straight out of surfing footage...
    I have wondered where that fine line was between cutting and not-exactly cutting. If you ever look a nicely machined surface.. that 32 or 16 finish under heavy magnification looks like the back side of the moon.
    Bob
  9. JC Sparks
    JC Sparks
    from Ohio
    It's hard to make any money cutting that slow! JC
  10. wsdad
    wsdad
    Cutting seems to introduce many, many small cracks into the surface of the work. Seems like uncut cold rolled steel would be stronger than cut cold rolled steel of the same diameter. I wonder what grinding looks like.
  11. GeezersP15
    GeezersP15
    from N.E. PA
    Thanks for posting that video. That was incredible. Almost looked like plowing snow instead of machining steel. :eek:
  12. ravedodger
    ravedodger
    I'm thinking I should have watched this video at 2:30 this morning after my teenaged daughter woke me up because of a supposed nightmare. Cool to watch and, yes, sleep inducing. I'm wondering if most work is as sloppy as that looks. It looked like the piling waste was doing most of the "cutting" in one of those clips.
  13. B Blue
    B Blue
    Very interesting, especially to see the actual "cut" to be a fracture above the the cut line and the workpiece deformed to proper diameter by the cutting tool. Who would have guessed? Maybe that is why it is sometimes impossible to take off less than a thou?
    Sure would like to examine the finish produced in the video!
    Bill
  14. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    That video is about 25 years old and part of it was H.S.S. vs carbide vs Carbide with T.I.N. coating ( ***anium Nitride ) when T.I.N. first came out to help prevent edge build up.
    The one section where the steel material build up on the carbide insert and the steel was re- cutting itself isn't a good thing
    It's all thermal in breaking down the molecules.
    In may cases today carbide cutting tool technology has surp***ed many machine capablities. Especially in Non Ferrous materials.
    New carbide coatings today like T.I.C.N. ( ***anium Carbo Nitride ) and T.I.A.L.N. ( ***anium Aluminium Nitiride) or ALTIN ( Aluminium Nitride) are even better yet to extend the insert life.
    In between hard 55-60 Rockwell - Cermet is good ( Ceramic ) Loves speed.
    Super hard stuff 60 rockwell and above CBN ( Cubic Boron Nitride)
    I remember watching that video over 25 years ago.
    It is still pretty cool.
  15. hotrodkiwi
    hotrodkiwi
    That's not what I expected! Amazing what you can see with a high speed camera.
  16. 53 ford
    53 ford
    That's why cams and cranks are ground.
  17. Roger Walling
    Roger Walling
    When I was in the navy, I watched a big "chip" being sheared off when two ships very slowly slid past each other. I was about 2' away and the "chip" was about 1/2" thick. No noise, and slower than the vidio.
  18. Like a hot knife through ****er. I had to turn it off too, I was starting to nod off.
  19. squirrel
    My guess is that it look pretty much the same, if you magnify it enough.
  20. Looks like cheese being sliced
  21. belair
    belair
    Wow-looked like fluid, not solid.
  22. pdunn10
    pdunn10
    wow, cutting tip appears to do very little to no actual cutting. amazing
  23. 40FordGuy
    40FordGuy
    wsdad,..... Optomist says gl*** is half full
    Pessimist says it's half empty
    Government says "we're taxing your gl***"
    4TTRUK
  24. hotrod40coupe
    hotrod40coupe
    It really shows the elasticity of metal.
  25. ClayMart
    ClayMart
    I'm thinking it probably looks like cutting, but with lots of fireworks! And with better music!
    I think I already knew this, but as previously stated, what we think of as "cutting" metal is actually "melting" metal at a molecular level. Like using a miniature cutting torch but with no flammable g***es required! :eek:
  26. Commish
    Commish
    from NW Ok
    That does not look like lathe turning to me, looks more like it was done on a planer or shaper, looks like a flat surface underneath to me, and 30 degrees rake is way more than I would put on a lathe tool, unless maybe turning aluminum.
  27. gimpyshotrods
    gimpyshotrods
    Ding! That is exactly what it looks like. Fluid-dynamics.
