What's so special about F100 drums/backing plates???
Discussion in 'The Hokey Ass Message Board' started by CharlieLed, Aug 20, 2006.
  1. CharlieLed
    CharlieLed
    I keep seeing posts about F100 brake drums and backing plates, what is so special about this setup? I have a couple of complete front suspensions from 53-55 F100s...do these make a good juice upgrade for mechanicals?
  2. djmartins
    djmartins
    That is exacctly why people want them.
    They are better than the ford juice brakes.
    regards,
    DJ
  3. Deuce Roadster
    Deuce Roadster
    The 53 to 56 F-100 Brakes are self energizing ... and the 65 - 66 self adjusters can be adapted very easily. Also all the parts except the backing plates are available at NAPA, Car Quest and the like ... :)
  4. CharlieLed
    CharlieLed
    Here's a pic of one of the backing plates, the guy went through the whole ch***is before I got it...all the backing plates and other hardware are all chromated and look like new.
  5. Anthony
    Anthony
    Chuck, I could use that stuff if it's going to end up in the cl***ifieds ...
    Not sure that I still got your number. You still live off Cyumaca?
    Also, I got a buddy that picked up a couple Northstars for a sand rail ... I think he's short a few peices. He might need some advice (or Jesus??, i think he's nuts).
  6. JimSibley
    JimSibley
    Do they bolt up? If not how hard to adapt?
  7. Yeah Jim they bolt right on a '48 car axles spindles.....backing plates and all.
    All that is required is a different INNER bearing and seal.....I did have to sand the surface on the spindle a tad so the bearing would install easily...I think as DeuceRoadster-Randy says ,a Timken bearing fits "outa the box"...I used a BCA bearing ,from O'reillys auto parts -may be an import?
    the TECK archive has the article with the part numbers -very helpful- do a search on F100 BRAKES.
  8. Scott
    Scott
  9. Deuce Roadster
    Deuce Roadster
    They fit " as is " on mine but almost every article I have ever read said to radius the ID of the bearing where it goes to the spindle ... or you will have trouble. Mine has 50 thousand plus miles with no issues But maybe I was lucky ... for once . I am planning on a redo of the 32 Roadster ... if I ever finished this darn 3W ... :( and I will radius the new bearings ... at that time
  10. Scott
    Scott
    I had to do very minimal grinding for proper fit
  11. CharlieLed
    CharlieLed
    Yeah, I'm still at the same place. Just getting on a plane this AM to DC, be back on Friday. Shoot me a PM. I can make your buddy a good deal on a pile of Northstar parts...they only come in piles!
  12. Deuce Roadster
    Deuce Roadster
    I have considered that maybe production tolerances stacked up in my favor ... I used Timken bearings ... and maybe the spindles were at the edge of tolerances when machined so many years ago. I have done this conversion many times ... and never had a problem and I never radiused a bearing ... but I always used Timkem ... from a old, old parts house. When I found he had them ... I bought ALL he had ... at 1955 prices ...
    I got 8 or 10 sets ( inner and outer ) for about what a 2 sets would cost NOW at the bearing distributor ... and the old guy was GLAD to sell them ...
  13. hot rod wille
    hot rod wille
    I used a set of 56 F-100 brakes on my roadster--used Buick drums as a "cover" for the real drums--Buick drums where out of spec so it was a perfect deal
  14. elcornus
    elcornus
    I dig the way that looks, and I'm gonna be running these brakes on my coupe. Do they offer any heat disapation/cooling effect to the drums?
    How much machining did it take to fit the buick drums over the F-100's?
    Anyone have a set of worn out buick drums they want to let go of??:D
  15. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    Elcornus, you can't do the drum over drum trick. I want to do it.. Man, you make me sound like a slave driver in your tag line.....You know you want to be here......EVILT
  16. elcornus
    elcornus
    Fine, I'll machine up yours at the same time as I do mine, ya slave driver!
    Yeah, I do want to be there, still recovering from the spinal Injections.
    I'ma send you a PM.
  17. hot rod wille
    hot rod wille
  18. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    I think that is a pretty cool idea to use those worn out buick brums.....Hope you don't mind us stealin your idea... EVILT
  19. hot rod wille
    hot rod wille
    No problem guys----we need all the ideas we can come up with
  20. Frank
    Frank
    Can you post up the Timken part numbers? This would be handy to have.
  21. Deuce Roadster
    Deuce Roadster
