Hot Rods What's the advantage of a 400 SBC?
Discussion in 'The Hokey Ass Message Board' started by pokey, Dec 1, 2010.
  1. I have a snotty 406 at the shop right now. Splayed steel mains, **** crank and rods, Dart heads, fuel injected tunnel ram, twin turbo, street motor. All I need to finish it is pistons right now. Should make 750hp on pump gas with no problems.
  2. Herdez
    Herdez
    Well, you know how it goes...The great debate. 3 versions... 330817,3951509 and 3951511 maybe even one more. I have a 2 bolt 509 with center freeze plug untapped. I'll correct myself, early 70s I myself think is the best. :) I can only ***ume this comparing them along side with the 70- 74 350 & 454 blocks with high nickel content. another, this is what the mortec website said before it went down.
    3951509....400...70-71...4
    3951509....400...74-80...2
  3. CoolHand
    CoolHand
    Alliance Vendor
    I've had three 509 blocks, all of which had two bolt mains.
    If I'm going to use a stock block for a race motor, the 509 is the one I look for ('cause you can't put splayed caps on a four bolt).
    You can break 'em (I've only got one of the three left ;) ), but you've gotta work at it.
  4. teddyp
    teddyp
    had i factory rebuilt 400 sbc in my 50 for years ran great the only problem i had was a butcher talk me into letting him redue the motor with a cam and head work screw up the oil rings it ran like hell but burn a qt of oil about every 250 miles with a 4 sp and a 4.11 read i could smoke alot of cars and i do mean smoke i went to a 300 hp 350 4 sp i still have the fly wheel if you need one for a stick
