Whats the best Tig welder for the money?
Discussion in 'The Hokey Ass Message Board' started by dsiddons, May 30, 2011.
  1. Ben James
    Ben James
    I have Everlast PowerPro 256S, the welder that 3-in-1 function included Stick, Tig and plasma cutter.
    This is the best tig welder.!
  2. 1946caddy
    1946caddy
    from washington
    I just blew a circuit board on my miller and the factory wanted $800 for new one. Got mine repaired by Nyco systems in Cal. for $286.
  3. 1946caddy
    1946caddy
    from washington
    If your serious about tig welding, get a machine with Pulse, You can get that cool stacked dime look to your welds and it helps with sheetmetal because of the cooling effect between pulses. It's possible to manually pulse but takes a lot of skill.
  4. Dan Timberlake
    Dan Timberlake
    I suspect it would be Best not to listen to anything like this when manually ( foot-ually?) pulsing .
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    I'd also 2nd looking for a good used unit.
    Don't be in a rush. Take your TIG class, get accomplished and try out as many units as you can. Look for something that has low miles. Maybe an auto repair shop or machine shop that's closing or a well outfitted home shop that has a TIG that didn't get a lot of use, rather than a production shop that ran the machine daily.
    Talk to the guys at your local welding supply. They may have demonstrators that come up for sale or may be selling a new TIG to a customer who wants a newer/larger TIG and has their older unit on the market.
  6. bambbrose
    bambbrose
    from So. Utah
    Just went through this exact same decision making process.
    Buying new, after all my research, on a budget I would pick the Miller diversion 165/180.
    If you are willing to spend a bit more, the Miller Syncrowave 210/250 are the next step up, but its a big step.
    As for what my final choice was? I found a Lincoln Square wave 175 with a massive tank, regulator, and cart for $800. Thing is in perfect shape. Buy used but stick with Lincoln/Miller and you'll be happy.
  7. woodiewagon46
    woodiewagon46
    from New York
    The shop I worked in for 22 years had 12 Miller machines of different varieties, from 220s to 351s all great machines. After I retired I wanted a TIG machine, but only need it occasionally, so I purchased an Eastwood machine and I am very happy with it, although it does not have the exact control on the foot pedal like the more expensive machines do. I am also concerned about replacement parts. Don't get me wrong, if I was doing a lot of work, or building a new car, I would have purchased a Miller, Lincoln or other production machine.
  8. dreracecar
    dreracecar
    from so-cal
    The best is the one you only have to buy once. Stay away from the old Miller syncro's, as the circut boards and other componants are very hard to come by and very expencive. When it became a problem I dumped it and went with a MILLER 350 Dynasty but its completely out of your range and skill level right now
  9. Kevin Lee
    Kevin Lee
    Super Moderator
    Interesting to hear the issues with ESAB and Millers.
    I've been watching this AHP welder for a while. I haven't heard of any major issues with it and the reviews and forum threads – when you can find the ones that aren't blatantly driven by AHP – seem to be all positive. They seem to be out in force answering questions about the machines and providing support too.
    http://www.amazon.com/AHP-AlphaTIG-...iewpoints=1&sortBy=bySubmissionDateDescending
  10. JOECOOL
    JOECOOL
    I had a lincoln years ago,when I would try to weld make fuel tanks out of 1/4 aluminum I would regret not having a bigger machine and a water cooled unit.Aluminum seems to eat up a lot of power.
  11. J. A. Miller
    J. A. Miller
    from Central NY
    Guys, this thread is almost 4 years old. I would think the OP has a machine by now.
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    And yet the thread is still here giving information.
    This is selfish but... I don't really care if the original poster has a machine or not! He'll take a look at the info in this thread and make his choice same as I am right now.
    31Vicky with a hemi likes this.
  13. Blue One
    Blue One
    from Alberta
    :rolleyes: No, it isn't.
  14. afaulk
    afaulk
    Lincoln Square Wave 175. Never a problem with it. Hundreds of hours of superb service.
  15. You'd be correct
    I like something by Bo diddley myself
  16. Still plenty of useful info, some threads are worth a bump
  17. belair
    belair
    Yep- I'm looking for info. ^^^
