what's the best way to drop a 48 ford pick up?
Discussion in 'The Hokey Ass Message Board' started by phil, Mar 26, 2009.
  1. phil
    phil
    what is the best way to drop the front end on a 48 ford pick up. It has the original front beam.
  2. Carter
    Carter
    Well, there are dropped axles available and I'm pretty sure I've seen that someone will drop your stock one.
    Dave
  3. phil
    phil
    I know i can by a new axle. I gess what i'm asking is what would be involved in droping the original axel? do I change spindels or do I heat it up.
  4. BenD
    BenD
    Alliance Member
    Call Sid at Droppedaxles.com
    SUPER Guy.
  5. Put a big block in it.
  6. Mudslinger
    Mudslinger
    Drop axle and remove a couple of springs.
  7. HOT40ROD
    HOT40ROD
    from Easton, Pa
    If you are going to remove the spring. remove the short one. The first time I found out the hard way not to remove the long ones. had the main spring break at 60 mph.
  8. havi
    havi
    Reverse the eyes, is another option.
