What's the best way to lower the front of a 54 Chevy?
Discussion in 'The Hokey Ass Message Board' started by orange52, Jan 26, 2010.
  1. orange52
    orange52
    I'm looking for a good, economical way to lower the front of my 54 chevy.
    I'm only looking to lower it 2-3 inches and will be keeping the original suspension.
    So far, I've found four options:
    1. shorter coil springs (~$120)(Chev's of the 40's)
    2. Dropped up rights (~$500) (RM engineering or FatMan)
    3. Front lowering blocks (~$80) (goes under the lower A Arms)(Chev's of the 40's)
    4. stepped lower a arms ($??, don't know anyone that can do this or what it'll cost)
    The blocks for under the front A Arms seem to be the best compromise of cost and keeping the ride quality.
    If I go with the blocks or shorter coils, will I need to modify the steering arms?
    What, in your opinion, is the best way to lower this car?
    Thanks
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I did mine in an afternoon, in my own garage.
    with general tools, nothin fancy. didnt cost me nothin but my time..oh and an alignment if you want to count that
    I cut the coil with a dewalt side grinder with a cutoff wheel.
    I put a jack under the control arm stay on the lower arm , took all the bolts out with the jack up under it (frame on stands) lowered the jack until the spring came loose. Cut it (do both springs exactly the same, i marked mine with a paint stick, and cut slow as to not heat up the spring) put em back up in there jacked the lower control arm back into place bolted it back up , and put the car back down..bounced it a few times to check it, than went and had it re-aligned..
    done..took me like 1.5 hours. I also replaced the anti sway bar bushings and new shocks
    I like it
    and it rides just fine
    this was my method..others will like to argue it..fine, your mileage may vary. But i didnt spend a dime just my time. and if i took more of my time im sure i could have done the alignment myself. It wasnt that far off the guy said.
    as for the naysayers "oh your spring is going to break" B.S. it can be done this way with no problems other than spring rate change, but in my case the rate change helped in handeling and doesnt bottom out.4 years now and plenty of hard assed Michigan road testing..I dont baby it.
    P.s. i started with 1.5 coils..ended up taking out about 2 coils or so.(if my memory serves me right) if i wanted more..i could go back at it and take another bite at it and drop it another 1" . But once the car is loaded down..with passengers and shit..it sits low enough. it doenst sit to be looked at, it gets driven in real world conditions, so its low enough
  3. 1bdsinner
    1bdsinner
    from phoenix
    cut coils here and lowering blocks minus a few leafs out the rear till I 4 link and coil over the rear. Also on a budget and its my daily beater till my 52 f1 gets done anyways. drive the dog piss outta it across Phoenix, went to Yuma for ghouls show.. no issues here...
  4. 1bdsinner
    1bdsinner
    from phoenix
    Sorry heres the pic of it
  5. holeshot
    holeshot
    from Waxahachie
    ORANG...first you said the best way, and then most economical. shit man which is it. the best way is blocks. economical is heat the coils with a torch...POP.
  6. BBYBMR
    BBYBMR
    Start by cutting 1.5 coils. Depending on the condition of your springs, that may or may not be enough. Like Von Rigg Fink said, it's easy to do and does not take much time.
  7. Was keeping mine to a budget as well wanting to do it the way the older guys on the block did it back in the day..;)
    Soooo, lowering blocks in the back and cut coils in the front. I only took about a coil and a half out of mine, which dropped it about the height of the bumper (4"?), but a buddy took nearly two out of his. ...I would start easy - you can always cut some more if necessary!
    -Dave
  8. Jims35
    Jims35
    Back in the fiftys not having any money we did it the cheap fast way . Not the way I would do it now . place two bumper jacks where you want the bumper to stop and heat the springs up. Get a beer , drink it, hit the road with your new ride . Like I said not the way I would do it now.
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I dont care what anyone tells you...dont ever heat your coils or any spring for that matter...it just negates the properties of spring steel..than all you have is shit,
    shit that will break, and shit that could cause you to fill your shorts with shit when they do..
    its not a matter if if it will break..its the fact, they will break..and potentialy causing a very dangerous situation for you your passengers and possibly anyone you are sharing the road with
  10. johnny bondo
    johnny bondo
    from illinois
    dropped uprights are the way to go with the stock suspension. it will give you alot more travel. ive done it the cut coil way and puckering up your ass on every bump kinda sucks ass! you could always channel the car over the frame too, that doesnt cost anything but timem and then take out like 1 or half a spring loop. heating the springs just makes them weak and more prone to bottoming out(takes the hardning out of them)
  11. narlee
    narlee
    I cut mine, like they said don't cut too much you can always cut more. After you cut it drive around the block to let the suspension settle before you you check it. Don't heat the springs, it will be lower but your springs will be trash.
  12. jadam54
    jadam54
    from DENVER
    I just heated up my coils with a torch
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
    This is what happens when you heat a coil with a torch until it collapses. Not good. Contrary to rumor, cutting off a coil with a torch won’t affect a spring’s heat treatment because only a small section of the spring really gets hot.
    but "sagging" the spring with heat does affect the heat treatment and the spring will eventually break or bend to the point of exit out of the pocket it was intended to stay in..possible equipment damage may result..or possible accident from an unprepaired driver when it decides to fly
    like most things..theres a right way and a wrong way, good luck on the latter
  14. mrhotwheels
    mrhotwheels
    I've got a rock stock beater '51 4-door Chev, will cutting the front springs and leaf removal work for mine too? How many leafs to remove before it settles to the right height? I want to drop the front about 3 inches, the rear about 2 1/2 for the rake. Can I fab up a set of lowering blocks for the rear instead? I've never cut springs before so...
  15. mrhotwheels
    mrhotwheels
    forgot the picture...
  16. Jims35
    Jims35
    To begin with , heating the springs is the wrong way . I would not tell anybody to do it. It looks like only one side was heated on that spring . We would heat it even all the way around and not to much at one time. I have removed them to replace with new ones when it was time to tradeup as dealers never wanted them. The heated springs would stand straight and I never did break one . But like you say there is a right and wrong and heat is wrong. I like dropped spindles , but thats just me .
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    depends on how much the stock springs are sagged at this point.
    my suggestion for getting 3" out of the front is to NOT take it all out of the springs to get it there..maybe a 2" lowering uprights, and 1" out of the springs if you buy the dropped uprights , get the dropped steering arms too(springs will need to be cut as you go kinda thing to get what you want..a little at a time type deal , dont shoot for all 3" out of your springs..it aint going to happen and the ride will suck ass)
    now for the rear, plenty of options..reverse eye main spring..blocks, or a combination of blocks reversed eye, and maybe a leaf out..or make a new set of lowering perches like i did for mine ( i went open drive line so i welded new perches designed to drop my rear 3.5" and retain the full spring pack and ride)
    about 3 to 3.5" is all your going to get out of the rear..the housing will bottom out alot if you go much lower with out a C notch and possibly a hole for your pumpkin in the trunk
    as always ..pay attention to scrubline issues when lowering anything
  18. billbrown
    billbrown
    The best way to lower your car is with a Big Block.
  19. Hyway Hauler
    Hyway Hauler
    You're an idiot!!
  20. 53sled
    53sled
    from KCMO
    eh only a few pounds more than a stovebolt.
  21. mrhotwheels
    mrhotwheels
    Thanks for the advice. So my question is can I take 1 1/2 coils from the front and lowering blocks in the rear with a closed driveline? Would the blocks be the safest way or should I remove some leafs or add shackles...or am I missing something. I'm not trying to lay frame, just give it a better look without having to worry too much about speed bumps.
    The car is box stock. How hard is it to convert it to an open driveline? I've never dealt with a closed driveline before so it's all new shit to me. (sorry if ya'll think this is a thread jacking)
  22. Antny
    Antny
    from Noo Yawk
    Cheapest way: let the air out of your front tires. :D
    Next cheapest: remove the coils and cut a coil out with a saw, not a torch.
    Best way: a clip, or a MII type crossmember.
    Just my $0.02, before taxes.
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah i would think you could get 1.5 coils out of the front without too much of an issue..sneak up on it.
    i personally wouldnt remove any spring leafs, but thats me after what i saw happen when a few others tried this and than had some of their leafs crack and break alsmost leaving their rear end in peril.
    try the lowering blocks first, or design of a new leaf perch on your rear end..dont short cut it..
    you will be bummed if you do
    Im running open drive line on mine..you still have the restriction of the frame and pumpkin bangin no matter what rear end, if you decide to go more than 3 or 3.5" thats when it will become an issue
    that picture of mine might be 1.5 coils on the front..i forget..but its no way more than 2. that im sure of
  24. mrhotwheels
    mrhotwheels
    Cool. I don't want to max it out leaving the diff to bang around all over the place so it looks like lowering blocks. Where can I get a good set? Sorry for all the damn questions...I'm a bit new to the scene, took a trip from muscle cars down to here.
  25. Von Rigg Fink
    Von Rigg Fink
    from Garage
    wish you were closer..we could knock this out in an afternoon with a few cold ones.
    if you are staying with the closed rear drive..lowering blocks might be the way to go for now..i think National Chevy might have them..not sure
    nationalchevyassoc.com
    you also have a PM
  26. Leadsled RnR
    Leadsled RnR
    from CO
    Not to highjack the thread, but hopefully add to it. I have the dropped uprights, and cut coils, and I think i'll want my 54 to sit just a little bit lower. A buddy suggested shimming the lower control arms on the crossmember. It was brought up earlier as lowering blocks for the front end. Who has tried this? What was the affect on the ride and steering? and how much does it really lower the car? thanks!
  27. Lone Star Mopar
    Lone Star Mopar
    DO NOT HEAT YOUR COILS!!!!!
    sorry for yelling.
  28. nutajunka
    nutajunka
    Easy well, letting the air out would be the quickest, but if your not married or anything maybe a couple 500 lb. women "would getter done real quick like"...:D
  29. Lone Star Mopar
    Lone Star Mopar
    We are kicking around the idea of just fabbing up new lower control arms for the 52 because we have access to the tools. However notching the a arms (assuming your a good welder) is a cheap and fairly common way to get about two inches then you can get the other inch from your coils and your good. Of course you will still need an alignment but your still in way less than 500$ and you shouldnt sacrifice to much suspension travel. I will be watching this thread as I am trying to get mine low before the roundup!!
  30. Lone Star Mopar
    Lone Star Mopar
    Anyone had any experience with blocks up front ?? Ive heard them mentioned but never seen em in action.
