Technical Whats the fe ford starter install secret?
Discussion in 'The Hokey Ass Message Board' started by theHIGHLANDER, Dec 4, 2023.
  1. Fortunateson
    Fortunateson
    Hey i thought you said you changed it in the middle of a blizzard?!
  2. bobss396
    bobss396
    Yes, freezing and during the 2nd 1978 blizzard. It was probably around 15 degrees with a wind chill of about -15...
    I pulled the car up on a packed snow bank in front of my house, dug out under it with a shovel. I laid on a piece of cardboard and went at it.
  3. Oneball
    Oneball
    I’ve just pulled mine out and the pinion is in what I’d describe as the on position, @theHIGHLANDER did you determine if there was a reason why it wasn’t fully returned?
  4. theHIGHLANDER
    theHIGHLANDER
    I haven't messed with it to see why. On my back burner as there's no immediate need, but yes, that's how mine came out. Does yours float or is it stuck too?
    Heavy *******, huh?
  5. Oneball
    Oneball
    I can move it about 1/8 inch towards the starter but not at all the other way. Where it is it’s gotta be spinning with the engine running.
    Didn’t think it was quite as heavy as a Chevy one!
  6. theHIGHLANDER
    theHIGHLANDER
    All my research says it should kick back upon upon engine start. Mine was stuck much the same way. I have a really nasty looking one too, all surface rusted that I might clean up and explore as well, but the literature and pics online all show it back, or away from the starter motor.
    Oneball likes this.
  7. 4 pedals
    4 pedals
    from Nor Cal
    A little newer, but still an FE. I had to change the starter in my 70 F100 parts chaser a few years ago, pulled the exhaust to do it. That lead to other issues with the upper bolts breaking, which lead to rebuilding the heads. I stopped there.
    Devin
  8. El Caballo
    El Caballo
    from Houston TX
    The Blizzard of ‘78, I was living in Hartford at that time, school was cancelled for quite some time and we loved it. My brother and I made money hand over fist shoveling walks and driveways.
    I never had to swap starters on my 1963 Galaxie 352, now I realise how fortunate I was.
    bobss396 likes this.
  9. bobss396
    bobss396
    Fun times. I was in the midst of a divorce and a small house gets REAL small when you are cooped up for 3 or 4 days with snow up to the outside window sills... :eek::eek::eek:. Suicide at the time was very much on the table.
