Technical What's the fix for sagging outside door handles.?
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Oct 16, 2021.
  1. The driver's side door handle on my '40 sags, not completely down, but enough that I find it annoying. How complicated is a fix? Thanks in advance and please no Viagra jokes.:)........Don.
  2. Good question, mine do that also.
    I'd also like to know.
  3. Stu D Baker
    Stu D Baker
    from Illinois
    I've seen guys take the handle and put the square shank in a vise. Heat the shank and give it a twist in the direction you need. The real problem is in a worn latch internals.
  4. Mine are a bit droopy amd on a 4 door it looks kinda silly with the handles side by side and a little droopy
    Hope there’s an easier fix then heat and bend
    lothiandon1940 likes this.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    This works great. And much easier than disassembling the whole setup.
    Don’t overheat though.
    egads, lothiandon1940 and VANDENPLAS like this.
  6. DON, I want to say that there is a spring in the door latch assembly that can be replaced to fix this. I know on my 36 chevy the spring is replaceable and available. I kinda remember that my 36 Fords door latch spring was reproduced also, try Bob Drake or ? for a set of springs. Good luck, Mitch. ☆☆I just used the GOOGLE and they are available from CW MOSS, Sacramento Vintage Ford, EGAY and others.....
    Tim, Hnstray, mad mikey and 3 others like this.
  7. bobd1976
    bobd1976
    from Illinois
    Replacing the springs are the right way to fix them.
    Tim, firstinsteele, Hnstray and 5 others like this.
  8. harpo1313
    harpo1313
    from wareham,ma
  9. 19Fordy
    19Fordy
    lothiandon1940 and rusty valley like this.
  10. rusty valley
    rusty valley
    This ^^^^ and, while its apart check to see that the bump on the cam inside is not worn down
  11. nochop
    nochop
    from norcal
    100% spring
    Bob Lowry and lothiandon1940 like this.
  12. Thanks everyone..........Don.
    lothianwilly71 likes this.
  13. The 39 guy
    The 39 guy
    Hello Don, I went back through my coupe build thread to find this for you. Heating and bending this brand new handle was an easy fix, I would say I was a little nervous about doing it. But it really was a simple fix. I have noticed that sometimes the old handles square shaft is worn causing the sag. Sometimes the socket in the latch is worn also. If either of those parts are worn I don't think this bending process is the best course of action. If the shaft is sloppy in the hole bending the shaft might help with the outside appearance but the handle will still be sloppy in the hole. Then again if the spring is broken or has just lost it's temper replacing it would be a viable option. The reason I had to bend mine was that the brand new Bob Drake latches positioned the handles 5 degrees down o_Oso buying new latches may not solve the problem. Well you have received plenty of advice here. Please let us know how you solve the problem.
    I think I touched on this subject earlier but I will bring it up again here. My brand new 40 Ford door handle and latch mechanisms had a about a 5 degree downward tilt when installed. I corrected the problem by heating the square shank with my torch and twisting it up a little with a 12 inch crescent wrench.
    To my surprise it worked and the handles are nice and straight.
  14. Excellent explanation and thanks a bunch @ The 39 guy. I'm guessing, that like you mentioned, both the the square shaft and the square hole are well worn. Along with a weakened spring, I'm sure it's likely a combination of factors. It's not completely dropped, just a "bit" droopy. I may hold off doing anything until I decide to purchase a new latch mechanism and tackle the fix.
    Very upsetting that you had to perform surgery on a brand new Drake piece. Glad it turned out OK for you, but that's still rather annoying.........Don.
  15. jim snow
    jim snow
    Had the same issue on my 41. Drivers side only. Found new old stock on the evil bay. Solved it. Snowman
    pprather and lothiandon1940 like this.
  16. BJR
    BJR
    " If the shaft is sloppy in the hole bending the shaft might help with the outside appearance but the handle will still be sloppy in the hole."
    Nothing worse that the shaft bering sloppy in the hole!:eek::p
  17. Petejoe
    Petejoe
    from Zoar, Ohio
    I’m sure if you run into any wear on the shaft or the hole a little weld would easily compensate for the loose fit.
    The 39 guy and lothiandon1940 like this.
  18. spanners
    spanners
    Droopy handle? They have blue pills for that.
    egads and '34 Ratrod like this.
  19. Guy Patterson
    Guy Patterson
    Only if he has a tig welder
  20. ..........See post #1.:rolleyes:
  21. The 39 guy
    The 39 guy
    I hope you don't have the same problem if you buy a new latch Don. It's an easy fix though. Adding metal to your handle shaft by welding is doable but more troublesome than replacing the latch imhop.
  22. Rusty Heaps
    Rusty Heaps
    The driver side handle on my ‘46 Chevy was sagging badly. I had to pull the lock assembly to do other repairs. While I had it out I used JB Weld, the long cure not the fast, on the brass part that supports the handle. I then filed it for a better fit, not perfect, but better than before. We’ll see how it works out. Hopefully it’ll last for a good while.
    lothiandon1940 and Algoma56 like this.
  23. finn
    finn
    Could be the spring is weak, the square hole in the latch is worn, or the square shaft of the handle itself is worn or twisted.
    Most likely it’s a combination of all of the above.
    On the other hand, as long as the doors latch, why worry about it? Sagging handles on old cars is traditional, after all.
    Joe Blow and lothiandon1940 like this.
  24. ..................I like your attitude.:)
    lothianwilly71 and Joe Blow like this.
