Technical what's the most you hp you can push out of a 1952 262 6cylinder, and mods to get there?
Discussion in 'The Hokey Ass Message Board' started by Hudson52sam, Oct 8, 2015.
  1. Hudson52sam
    Hudson52sam
    I've seen pics of a super charger mounted on the side, but not sure if it was a 262 or a 308 or a newer 308, was reading they made the motors better in 1955 where the motor could handle performance mods,
  2. Rusty O'Toole
    Rusty O'Toole
    Stock was 127HP. You can getup to another 40 HP with normal mods or with a supercharger. The 308 continued until 1956. Last year for the 262 was 1954.
    If I had a 262 I would leave it stock or maybe do a mild hop up for laughs. But only after tearing the engine down and making sure rings, bearings, valves, oil pump etc are up to spec. An old engine may run for years if you baby it, but blow sky high as soon as you try to hop it up.
    Hudson52sam likes this.
  3. Hello Rusty,Your Best move would get a 55 308 block put a 232 head on it,put bigger values in it,get a Clifford hot cam for it,headers and a electronic dist,and drive the hell out of it! As one Hudson owner to another"Happiness is a Hot Rod Hudson" Uncle Bill
  4. mountainman2
    mountainman2
    "what's the most hp you can push out of a 1952 262 6cylinder"
    for how long ???:rolleyes:
  5. Hudson52sam
    Hudson52sam
  6. Hudson52sam
    Hudson52sam
    Uncle Bill , that's the plan I was leaning more towards, I want to keep a hudson motor in it, rusty I've rebuilt the motor and trans and clutch, nothing fancy , but would defiantly go a different direction on rebuild if , I go to hop it up
  7. Hudson52sam
    Hudson52sam
    Heard from another guy he use to toss in moth balls , not to sure about all that, lol
  8. Hudson52sam
    Hudson52sam
  9. Hudson52sam
    Hudson52sam
    Here's a question how much modification is needed to put the 308 in ?
  10. Hudson52sam
    Hudson52sam
